Starting a new BSP
Joel Sherrill
joel.sherrill at OARcorp.com
Wed Mar 19 14:12:05 UTC 2003
Peter Mueller wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hello,
> is there an up-to-date description on how to add a new BSP to rtems?
> Or the other way around - does the bsp doc reflecting the current
> snapshot?
Offhand, I am not 100% sure that the online version is based upon
the current source but the source in 4.6 pre1 was updated just prior
to pre1 being cut. So an attempt has been made to make it current.
If you find mistakes, point them out.
I am also nearly finished updated the Development Environment Guide
so that should be in pre2.
That leaves folding the Getting Started with GNAT/RTEMS manual into the
main Getting Started now that Ada is included with main-stream gcc
and that is how RTEMS supports it.
> Thanks,
> Peter
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v1.0.7 (GNU/Linux)
> iD8DBQE+d2dMUzCcwYQMTJoRAvgQAKCeDGsAeRXp/sWDltaaCVuRblFUBQCeJO6M
> pqKAyXGt4Tq7HNYaJqLNCNY=
> =Jjzi
> -----END PGP SIGNATURE-----
joel at OARcorp.com On-Line Applications Research
