ACE TAO RTEMS build
Jack Cawkwell
J.Cawkwell at open.ac.uk
Mon Mar 24 16:30:48 UTC 2003
Joel,
I made no changes to RTEMS, only to ACE. The TAO base was OK, but I had
(obviously) problems compiling the tao_idl preprocessor, which I copied
from
a native i386 linux build of tao. The changes I made are 'hacks' and need
to be converted into proper precompiler instructions.
I had a quick look at compiling tests. I found the file that will call the
tests, but it looked a bit bare. Also I wish to load the image using
netboot,
and although I have this working with a picodemo pre-built image, I have
not
yet been able to build an image that will netboot. I am still looking into
all this....
Jack
Joel Sherrill <joel.sherrill at oarcorp.com> writes:
>Jack Cawkwell wrote:
>> Joel,
>> I managed to build the basic parts of ACE and TAO for rtems over the
>> weekend.
>> There were some problems with OS.h, and the rtems.conf file, to do with
>the
>> function signatures of alarm, signal and its arguments. To resolve
>these I
>> just altered the code crudely, and it probably needs to be driven
>properly
>> from the config file. I doubt I can do this, so who should I ask? Some
>one
>> from the rtems community or the ACE/TAO people? I am using ACE 5.3/TAO
>1.3/
>> rtems 4.6-pre1 from the cd version.
>Are the changes strictly to ACE/TAO? Is RTEMS doing "The Right Thing"
>POSIXically speaking?
>> I will grep out the changes, (I will get email at home this week),
>> and post them here soon.
>OK. I suspect that they need to be posted here and reviewed but the
>ultimate destination needs to be the ACE/TAO users.
>Have you run any tests?
>> Jack
>Joel Sherrill, Ph.D. Director of Research & Development
>joel at OARcorp.com On-Line Applications Research
>Ask me about RTEMS: a free RTOS Huntsville AL 35805
>Support Available (256) 722-9985
