Ethernet (Raw)
gregory.menke at gsfc.nasa.gov
Tue Mar 25 18:46:28 UTC 2003
Erwin Rol writes:
> On Tue, 2003-03-25 at 18:12, Joel Sherrill wrote:
> > Look for tap in the networking guide and see if that helps. I don't
> > know if it is far enough into the stack to help.
> The TAP interface is only the receiving part ( right ? ). I hacked up
> something like that for RTEMS 4.0 too, the problem was sending raw (or
> almost raw , IPX) frames.
Its right above the driver itself- its a raw ethernet frame.
Depending on the if_tap function's return value, the packet is either
passed to the tcp/ip stack or discarded.
Gregm
