Ethernet (Raw)
gregory.menke at gsfc.nasa.gov
Tue Mar 25 19:27:23 UTC 2003
Joel Sherrill writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > Erwin Rol writes:
> > > On Tue, 2003-03-25 at 18:12, Joel Sherrill wrote:
> > > > Look for tap in the networking guide and see if that helps. I don't
> > > > know if it is far enough into the stack to help.
> > > The TAP interface is only the receiving part ( right ? ). I hacked up
> > > something like that for RTEMS 4.0 too, the problem was sending raw (or
> > > almost raw , IPX) frames.
> > Its right above the driver itself- its a raw ethernet frame.
> > Depending on the if_tap function's return value, the packet is either
> > passed to the tcp/ip stack or discarded.
> Does the standard FreeBSD stack have a facility like this that was
> not enabled/ported?
> If not, then can the tap design/interface be used as a model to
> provide the write side?
I don't know to both questions. if_tap operates at the very bottom
layer of the ip stack, just after the driver submits the ethernet
frame to it. The sending side looks fairly involved with a
per-interface send queue. I would be suprised if there wasn't a hook
in there someplace. Do you know if SOCK_RAW is supported by the
stack?
Gregm
