OK, so Which bsd and which driver?
gregory.menke at gsfc.nasa.gov
Wed Mar 26 20:53:54 UTC 2003
Joel Sherrill writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > Ralf Corsepius writes:
> > > Am Mit, 2003-03-26 um 18.16 schrieb gregory.menke at gsfc.nasa.gov:
> > > > Joking aside, Joel, please don't take this the wrong way- but this
> > > > kind of thing is EXTREMELY frustrating. I really wish these licensing
> > > > issues were made more plain.
> > > You are mixing up things, here:
> > > Basically, RTEMS comes with no restrictions on licensing.
> > > Linux is GPL'ed.
> > > => Nothing prevents _you_ from using Linux-code with RTEMS if obeying
> > > the restrictions of the GPL.
> > > It's only that GPL'ed code can not be merged back into the "official
> > > RTEMS sources" because this would imply having to put RTEMS under the
> > > GPL.
> > Of course- thats my point. I <want> to put my work back into RTEMS,
> > without imposing any sort of constraints on RTEMS. I am quite aware
> > of the license issue- and am only annoyed because the incompatiblity
> > is not made public in any obvious way ahead of time.
> Very good point. Where would you have looked to find this information?
> This is definitely a problem that comes up from time to time and if
> a writeup somewhere will solve it, then it is an easy fix.
I would probably have seen something like a README.GPL in the top
level directory. All I would have needed was a paragraph saying OAR
cannot accept GPL'ed code into the RTEMS tree. I don't have any
problems with the policy, but it would have saved a bit of work if I
had known it previously.
> > > > Sure, I could use it in-house, which I probably
> > > > would, but thats not helping the RTEMS community any.
> > > Well, the idea of setting up a GPL'ed RTEMS and a non-GPL'ed one has
> > > been discussed several times before, but AFAICT hasn't made it, so far
> > I'm not advocating such a thing. I don't get religious about software
> > licenses as such- the GPL and the bsd model serve somewhat different
> > constituencies, they both have advantages and I personally support
> > them both, morally and financially. However, my grumpiness is due to
> > the fact that I would not be able to contribute a GPL derived driver
> > back into RTEMS- and that policy is not clearly stated ahead of time.
> It is a pain. But I believe it is necessary to ensure RTEMS does not
> impose any license burdens on applications.
I have no problem with the pain- I completely respect OAR's licensing
policy, as I respect also respect the GPL. I'm just grouchy because I
had to throw away the work I had begin- I guess I should have broached
the subject before diving in.
> > So, I'm dumping the work I did and will work off one or another bsd's
> > driver, which I'll run to ground at some point. I'm looking at
> > freebsd's if_xl.c at the moment, which looks like it supports a
> > variety of 3com devices.
> FreeBSD, NetBSD and OpenBSD have been used by various people to
> grab drivers from at different times.
Cool- so no license issues.
Gregm
