4.6.0pre3 available
Derick Hammond derick at perkinstechnologies.com.au
Thu May 1 06:04:41 UTC 2003
Hi Chris:
I have tried the following, as I too wish to build my BSP outside of the
RTEMS source tree:
$ ../rtems-4.6.0pre3/configure --enable-multilib
--prefix=/tmp/test-m68k-rtems --target=m68k-rtems
$ make RTEMS_BSP="" all
But I had the following error during the make process:
gmake[3]: Entering directory
`/home/derickh/rtems/build-m68k-rtems/m68k-rtems/cpukit/libmisc/capture'
mkdir o-optimize
m68k-rtems-gcc --pipe -DPACKAGE_NAME=\"rtems-cpukit-libmisc\"
-DPACKAGE_TARNAME=\"rtems-cpukit-libmisc\" -DPACKAGE_VERSION=\"4.6.0pre3\"
-DPACKAGE_STRING=\"rtems-cpukit-libmisc\ 4.6.0pre3\"
-DPACKAGE_BUGREPORT=\"rtems-bugs at OARcorp.com\"    -isystem
../../../lib/include        -g -Wall  -o o-optimize/capture.o -c
../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture.c
../../../lib/include        -g -Wall  -o o-optimize/capture-cli.o -c
../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c
../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c: In
function `rtems_capture_task_time':
../../../../../rtems-4.6.0pre3/cpukit/libmisc/capture/capture-cli.c:1468:
Internal compiler error in instantiate_virtual_regs_1, at function.c:3971
Please submit a full bug report,
with preprocessed source if appropriate.
See <URL:http://www.gnu.org/software/gcc/bugs.html> for instructions.
gmake[3]: *** [o-optimize/capture-cli.o] Error 1
gmake[3]: Leaving directory
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
`/home/derickh/rtems/build-m68k-rtems/m68k-rtems/cpukit/libmisc'
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/home/derickh/rtems/build-m68k-rtems/m68k-rtems/cpukit'
make: *** [all-recursive] Error 1
I note that there is a difference in the tools you used to compile RTEMS.
Is there a reason to use gcc-3.2.3 over gcc-3.2.2?
Any hints or tips to diagnose this problem would be greatly appreciated.
System:
Redhat 7.3 - kernel-2.4.18-26.7.x
RTEMS Packages installed:
autoconf-rtems-2.57-1
automake-rtems-1.7.2-1
rtems-base-binutils-2.13.2.1-2
m68k-rtems-binutils-2.13.2.1-2
rtems-base-gcc-gcc3.2.2newlib1.11.0-2
m68k-rtems-gcc-gcc3.2.2newlib1.11.0-2
Modified RTEMS Packages:
rtems-base-gdb-5.2-P2
m68k-bdm-rtems-gdb-5.2-P2
Regards,
Derick Hammond
Chris Johns wrote:
>Joel Sherrill wrote:
>>Now we can worry about what real problems need to be
>>there. :)
>None for me. :-)
>I have successfully tested C & C++ (STL) apps with this release using the
>released gcc-3.2.3 + newlib-1.11.0 + binutils-2.13.2.1 tool set for the
>Coldfire processor (5206e + 5272).
>I used the multilib option and built no BSPs (gmake RTEMS_BSP=""). The
>multilib option is excellent and removes my need to use the bare BSP.
>Excellent effort.
>  Chris Johns, cjohns at cybertec.com.au
