Build problem with rtems-ss-20030417, when compiling & linking the hello app
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Fri May 2 15:06:55 UTC 2003
Eric Valette writes:
 > gregory.menke at gsfc.nasa.gov wrote:
 > > powerpc-rtems-gcc --pipe -B../../../../../lib/ -B../../../../../mcp750/lib/ -specs bsp_specs -qrtems
 > > enabling multilib doesn't affect the problem.
 > > Thanks for any hints,
 > > Gregm
 > This is due to my patch to fix the initialization problem on Intel. But
 > I think you are using old newlib include files... (did you install
 > really install newlib-1.11 it?)
There was some older newlib cruft hanging around, when I deleted all
the previously installed powerpc gcc stuff, then it worked fine...
Thanks,
Gregm
