How to migrate RTEMS to a target board?
elieli elieli at 163.com
Sun May 4 11:13:48 UTC 2003
My board is made by a China firm. if you want to know more, you can visit its website--www.wanhenet.com.
I only used the tools that this firm gave. sorry, I can't answer your questions clearly, for I am a beginner.
Eli
elieli wrote:
> Hi,Matt
> Thanx, and I had already made a floppy and run some applications. But
> my target board is ColdFire MFC5307.
> Can I create an image file as uClinux does? When I load uClinux
> onto my board, only I need to re-make it and load the image file.
> Any hints are welcome
You need to build RTEMS for the m68k target.
What is your board and what uCLinux target did you select ?
What boot monitor are you using (eg Dbug) ?
 Chris Johns, cjohns at cybertec.com.au
