m68302 boot problem - newbie!!!,
Nicolas PIGEON pigeon.nicolas at wanadoo.fr
Fri May 9 07:45:07 UTC 2003
Hi everybody,
Here are the tools I use:
gcc 2.95.2
newlib 1.8.2-7
binutils 2.9.5.0.24-1
rtems 4.5.0
and the linker script (in fact, there are 3 scripts: linkcmds, rom and debugger, but it seems only linkcmds is used):
_RamBase = DEFINED(_RamBase) ? _RamBase : 0x00100000;
_RamSize = DEFINED(_RamSize) ? _RamSize : 1M;
_HeapSize = DEFINED(_HeapSize) ? _HeapSize : 0x10000;
_StackSize = DEFINED(_StackSize) ? _StackSize : 0x1000;
 * Declare on-board memory.
MEMORY {
          ram : ORIGIN = 0x00100000, LENGTH = 1M
SECTIONS
	ram : {
	} >ram
	.vtable :
		vtable_start = .;
		*(.vtable)
		evtable = .;
	} >ram
         * Text, data and bss segments
        .text : {
                *(.text)
		 * C++ constructors/destructors
		*(.gnu.linkonce.t.*)
		 * Initialization and finalization code.
     		 * blah blah...
		PROVIDE (_init = .);
		*crti.o(.init)
		*(.init)
		*crtn.o(.init)
		PROVIDE (_fini = .);
		*crti.o(.fini)
		*(.fini)
		*crtn.o(.fini)
     		 * blah blah too...
		. = ALIGN (16);
		*crtbegin.o(.ctors)
		*(.ctors)
		*crtend.o(.ctors)
		*crtbegin.o(.dtors)
		*(.dtors)
		*crtend.o(.dtors)
		 * Exception frame info
		. = ALIGN (16);
		*(.eh_frame)
		 * Read-only data
		. = ALIGN (16);
		_rodata_start = . ;
		*(.rodata)
		*(.gnu.linkonce.r*)
                 . = ALIGN (16);
                PROVIDE (_etext = .);
        } >ram
        .data : {
                PROVIDE (_copy_start = .);
                *(.data)
		*(.gnu.linkonce.d*)
		*(.gcc_except_table)
                . = ALIGN (16);
                PROVIDE (_edata = .);
                PROVIDE (_copy_end = .);
        } >ram
        .bss : {
                _clear_start = .;
                *(.bss)
                *(COMMON)
                . = ALIGN (16);
                PROVIDE (end = .);
                . += _StackSize;
                . = ALIGN (16);
                _stack_init = .;
                _clear_end = .;
                _WorkspaceBase = .;
        } >ram
m302 = MC68302_BASE;
_VBR = ADDR(.vtable);		/* location of the VBR table (in RAM) */
When I use objdump with the generated exe, all the addresses begin with 0x001xxxxx, which is OK after the chip select swap (before, RAM=001xxxxx ROM=000xxxxx, after RAM=000xxxxx ROM=001xxxxx). But RAM addresses seem to begin by 001xxxxx in the code too (ex: reference to _WorkspaceBase, whose address is 001abcde=in ROM!!!). It's clear that it's a linker script problem... Consequently, the RAM is never used, exept for the copy of the vector table which uses explicit addresses, and the processor stops somewhere...
Thanks for any help!!
