atexit()
Brett Swimley
brett.swimley at aedinc.net
Wed May 21 17:42:37 UTC 2003
Hi all -
I'm getting some strange behavior occasionally when initializing my
application. My clock initialization function calls atexit to register a
clock driver exit procedure. Most times it works fine, but occasionally I
get a bad pointer.
Looking with my debugger where the error occurs, it appears that the
_impure_ptr is NULL. Is there any initialization I need to perform to get
the _impure_ptr set up correctly?
I'm using gcc-3.2.3, newlib 1.11.0, binutils-2.13.2.1, and
rtems-ss-20030417. I've applied some optimization patches to
gcc-3.2.3/binutils/and newlib for the Coldfire.
TIA,
Brett
Brett Swimley
Advanced Electronic Designs, Inc.
406-585-8892/406-585-8893 (fax)
