m68k clock problem
Chris Johns cjohns at cybertec.com.au
Fri May 23 05:42:47 UTC 2003
Nicolas PIGEON wrote:
> Hi,
> It seems I have a little problem with the ods68302 clock driver. Let me explain:
 > I managed to run hello.exe, but as soon as I try to run a sample using the clock
driver,
 > which defines CONFIGURE_TEST_NEEDS_CLOCK_DRIVER or uses its own driver table,
there's a
 > "trace" exception (vector number 9) when the 68302 returns from the first call to
 > Context_Switch (in Thread_start_multitasking). I forced the 68000's trace bit to 0,
 > but it's the same. I checked if the clock driver's interrupt vector was OK, and
 > it is (it refers to _ISR_Handler). I really don't understand what happens, and
 > I would really appreciate any help or idea....
Would it be possible to get the gdb stub working ?
It is part of BSP sources and would making getting past this point easier.
> Thanks!
> PS: For those who are using the ods68302 BSP, the reset.S file doesn't seem to work when
 > configuring the stack pointer. I'll post a patch ASAP
Please raise a PR and attach the patch.
  Chris Johns, cjohns at cybertec . com . au
