Reading from physical addresses..
Fernando RUIZ
correo at fernando-ruiz.com
Fri May 2 10:26:26 UTC 2003
On Thu, 1 May 2003 23:24:29 -0400 (EDT), Shailesh Hingole wrote:
> Message-Id: <Pine.SOL.4.21.0305012317230.21925-100000 at opal>
> List-Help: <mailto:rtems-users-help at oarcorp.com>
> List-Unsubscribe: <mailto:rtems-users-unsubscribe at oarcorp.com>
> From: Shailesh Hingole <shingole at cs.binghamton.edu>
> Date: Thu, 1 May 2003 23:24:29 -0400 (EDT)
> Received: (cpmta 5901 invoked from network); 1 May 2003 20:26:01 -0700
> Received: from 216.107.91.226 (HELO mail.oarcorp.com)
> by smtp.c007.snv.cp.net (209.228.33.248) with SMTP; 1 May 2003 20:26:01 -0700
> Received: (qmail 19729 invoked by uid 330); 2 May 2003 03:24:32 -0000
> Received: (qmail 19723 invoked from network); 2 May 2003 03:24:32 -0000
> Mailing-List: contact rtems-users-help at oarcorp.com; run by ezmlm
> Content-Type: TEXT/PLAIN; charset=US-ASCII
> X-Received: 2 May 2003 03:26:01 GMT
> List-Post: <mailto:rtems-users at oarcorp.com>
> Subject: Reading from physical addresses..
> In-Reply-To: <3EB119D5.A4BAF0BC at OARcorp.com>
> List-Subscribe: <mailto:rtems-users-subscribe at oarcorp.com>
> X-No-Archive: yes
> Precedence: bulk
> Delivered-To: fernando-ruiz.com%correo at fernando-ruiz.com
> Delivered-To: mailing list rtems-users at oarcorp.com
> Return-Path: <rtems-users-return-7579-correo=fernando-ruiz.com at oarcorp.com>
> MIME-Version: 1.0
> X-Sender: shingole at opal
> To: rtems-users at oarcorp.com
> Hi there,
> I need to read from a range of physical addresses (for
> ex. 0x000-0x1000) from an application in RTEMS. When I say that, these are
> the actual locations on the physical memory and not on the process address
> space.
> What is the best way to do it?
> Is it possible to do it from an application?
Hi,
My experience is that you are free to build a C pointer in order to read/write the I/O memory
mapped space.
unsigned short char * pb = (unsigned short char *) 0x008000;
*pb=15 by example.
You can do this always like a label in your link file memory map and declare like an external
variable in your C program.
The physical memory is the real memory at least in my experience (sh HITACHI and pc386 cpus).
Drivers need to do this. I have flash memory, rtc, uarts, and more devices and always I declare a
structure and declare like external variable from C.
I can set up the memory adress after in the link file when the linking process.
Is it right for all CPU's?
BRGDS.
> thanks,
> Shailesh
RUE DE LA GARE
LE CLOS DES GENETS, VILLA 51
69730 GENAY
TELEPHONE: 04 72 08 99 25
PORTABLE : 06 80 38 54 10
EMAIL : correo at fernando-ruiz.com
