How to migrate RTEMS to a target board?
    Chris Johns
    cjohns at cybertec.com.au
    Sat May  3 22:47:52 UTC 2003
elieli wrote:
> Hi,Matt
> Thanx, and I had already made a floppy and run some applications. But
> my target board is ColdFire MFC5307.
> Can I create an image file as uClinux does? When I load uClinux
> onto my board, only I need to re-make it and load the image file.
> Any hints are welcome
You need to build RTEMS for the m68k target.
What is your board and what uCLinux target did you select ?
What boot monitor are you using (eg Dbug) ?
 Chris Johns, cjohns at cybertec.com.au
