IDE support.
Angelo Fraietta
angelo_f at bigpond.com
Sun May 18 02:32:53 UTC 2003
I forgot the header
Angelo Fraietta wrote:
> Chris Johns wrote:
>> Hell Angelo,
> It gets a bit like that sometimes
>> I hope you are staying dry in this wet weather.
>> I am tring to get an IDE interface working under RTEMS. I currently
>> cannot find any doco on how this software all goes together and the
>> mail archives have you asking these questions a while ago. This is
>> the reason for the email.
>> I understand Thomas sent you a README. Also you asked for a simple
>> demo app. I would also like one.
>> I would like to achieve a couple of things, first get my IDE hardware
>> to work :-), and pull all the doco together and get it into CVS.
>> I feel your help would be invaluable to me and RTEMS.
> The fsmount are the files needed to get the dsofs working.
> the init.c is the example that came with patch-- it is quite easy to
> understand
> To get it working for me, I included the fsmount into my project and
> added the functionality from init.c into my project.
> I have it working in my embedded target quite well.
>| Project: RTEMS fsmount |
>| File: fsmount.c |
>| Copyright (c) 2003 IMD |
>| Ingenieurbuero fuer Microcomputertechnik Th. Doerfler |
>| <Thomas.Doerfler at imd-systems.de> |
>| all rights reserved |
>| this file contains the fsmount functions. These functions |
>| are used to mount a list of filesystems (and create their mount |
>| points before) |
>| The license and distribution terms for this file may be |
>| found in the file LICENSE in this distribution or at |
>| http://www.OARcorp.com/rtems/license.html. |
>| date history ID |
>| 02.07.03 creation doe |
>#include <rtems.h>
>#include <rtems/fsmount.h>
>#include <stdio.h>
>#include <stdlib.h>
>#include <string.h>
>#include <errno.h>
>#include <imfs.h>
>#include <sys/stat.h>
>| Function: |
>int rtems_fsmount_create_mountpoint
>| Purpose: |
>| This function will create the mount point given |
>| Input Parameters: |
> const char *mount_point
>| Return Value: |
>| 0, if success, -1 and errno if failed |
> int rc = 0;
> char *tok_buffer = NULL;
> char *token = NULL;
> int token_len;
> size_t total_len;
> IMFS_token_types token_type;
> struct stat file_info;
> * allocate temp memory to rebuild path name
> tok_buffer = calloc(strlen(mount_point)+1,sizeof(char));
> token = tok_buffer;
> total_len = 0;
> do {
> * scan through given string, one segment at a time
> token_type = IMFS_get_token(mount_point+total_len,token,&token_len);
> total_len += token_len;
> strncpy(tok_buffer,mount_point,total_len);
> tok_buffer[total_len] = '\0';
> if ((token_type != IMFS_NO_MORE_PATH) &&
> (token_type != IMFS_CURRENT_DIR) &&
> (token_type != IMFS_INVALID_TOKEN)) {
> * check, whether segment exists
> if (0 != stat(tok_buffer,&file_info)) {
> * if not, create directory
> rc = mknod(tok_buffer,S_IRWXU | S_IRWXG | S_IRWXO | S_IFDIR,0);
> } while ((rc == 0) &&
> (token_type != IMFS_INVALID_TOKEN));
> * return token buffer to heap
> if (tok_buffer != NULL) {
> free(tok_buffer);
> return rc;
>| Function: |
>int rtems_fsmount
>| Purpose: |
>| This function will create the mount points listed and mount the file |
>| systems listed in the calling parameters |
>| Input Parameters: |
> const fstab_t *fstab_ptr,
> int fstab_count,
> int *fail_idx
>| Return Value: |
> int rc = 0;
> int tmp_rc;
> int fstab_idx = 0;
> rtems_filesystem_mount_table_entry_t *tmp_mt_entry;
> boolean terminate = FALSE;
> * scan through all fstab entries;
> while (!terminate &&
> (fstab_idx < fstab_count)) {
> tmp_rc = 0;
> * create mount point
> if (tmp_rc == 0) {
> tmp_rc = rtems_fsmount_create_mountpoint(fstab_ptr->mount_point);
> if (tmp_rc != 0) {
> if (0 != (fstab_ptr->report_reasons & FSMOUNT_MNTPNT_CRTERR)) {
> printf("fsmount: creation of mount point \"%s\" failed: %s\n",
> fstab_ptr->mount_point,
> strerror(errno));
> if (0 != (fstab_ptr->abort_reasons & FSMOUNT_MNTPNT_CRTERR)) {
> terminate = TRUE;
> rc = tmp_rc;
> * mount device to given mount point
> if (tmp_rc == RTEMS_SUCCESSFUL) {
> tmp_rc = mount(&tmp_mt_entry,
> fstab_ptr->fs_ops,
> fstab_ptr->mount_options,
> fstab_ptr->dev,
> if (tmp_rc != RTEMS_SUCCESSFUL) {
> if (0 != (fstab_ptr->report_reasons & FSMOUNT_MNT_FAILED)) {
> printf("fsmount: mounting of \"%s\" to"
> " \"%s\" failed: %s\n",
> fstab_ptr->dev,
> strerror(errno));
> if (0 != (fstab_ptr->abort_reasons & FSMOUNT_MNT_FAILED)) {
> terminate = TRUE;
> rc = tmp_rc;
> else {
> if (0 != (fstab_ptr->report_reasons & FSMOUNT_MNT_OK)) {
> " \"%s\" succeeded\n",
> fstab_ptr->dev,
> if (0 != (fstab_ptr->abort_reasons & FSMOUNT_MNT_OK)) {
> terminate = TRUE;
> * proceed to next entry
> if (!terminate) {
> fstab_ptr++;
> fstab_idx++;
> if (fail_idx != NULL) {
> *fail_idx = fstab_idx;
> return rc;
>| File: fsmount.h |
>| points before) |
>| date history ID |
>#ifndef _FSMOUNT_H
>#define _FSMOUNT_H
>#include <rtems.h>
>#include <rtems/libio.h>
>#include <rtems/libcsupport.h>
> * bits to define, what errors will cause reporting (via printf) and
> * abort of mount processing
> * Use a combination of these bits
> * for the fields "report_reasons" and "abort_reasons"
>#define FSMOUNT_MNT_OK 0x0001 /* mounted ok */
>#define FSMOUNT_MNTPNT_CRTERR 0x0002 /* cannot create mount point */
>#define FSMOUNT_MNT_FAILED 0x0004 /* mounting failed */
>typedef struct {
> char *dev;
> char *mount_point;
> rtems_filesystem_operations_table *fs_ops;
> rtems_filesystem_options_t mount_options;
> unsigned16 report_reasons;
> unsigned16 abort_reasons;
>} fstab_t;
>| Function: |
>int rtems_fsmount
>| Purpose: |
>| Input Parameters: |
> const fstab_t *fstab_ptr, /* Ptr to filesystem mount table */
> int fstab_count, /* number of entries in mount table*/
> int *fail_idx /* return: index of failed entry */
>| Return Value: |
>#endif /* _FSMOUNT_H */
>/* Init
> * This routine is the initialization task for this test program.
> * It is called from init_exec and has the responsibility for creating
> * and starting the tasks that make up the test. If the time of day
> * clock is required for the test, it should also be set to a known
> * value by this function.
> * Input parameters: NONE
> * Output parameters: NONE
> * COPYRIGHT (c) 1989-1999.
> * On-Line Applications Research Corporation (OAR).
> * The license and distribution terms for this file may be
> * found in the file LICENSE in this distribution or at
> * http://www.OARcorp.com/rtems/license.html.
> * init.c,v 1.11 2000/06/12 15:00:12 joel Exp
>#define CONFIGURE_INIT
>#include "system.h"
>#include <stdio.h>
>#include <string.h>
>#include <unistd.h>
>#include <stdlib.h>
>#include <errno.h>
>#include <rtems.h>
>#include <fcntl.h>
>#include <rtems/error.h>
>#include <dosfs.h>
>#include <ctype.h>
>#include <rtems/ide_part_table.h>
> * Table of FAT file systems that will be mounted
> * with the "fsmount" function.
> * See cpukit/libmisc/fsmount for definition of fields
>fstab_t fs_table[] = {
> "/dev/hda1","/mnt/hda1",
> &msdos_ops, RTEMS_FILESYSTEM_READ_WRITE,
> FSMOUNT_MNT_OK | FSMOUNT_MNTPNT_CRTERR | FSMOUNT_MNT_FAILED,
> 0
> "/dev/hda2","/mnt/hda2",
> 0
> "/dev/hda3","/mnt/hda3",
> 0
> "/dev/hda4","/mnt/hda4",
> 0
> "/dev/hdc1","/mnt/hdc1",
> 0
> "/dev/hdc2","/mnt/hdc2",
> 0
> "/dev/hdc3","/mnt/hdc3",
> 0
> "/dev/hdc4","/mnt/hdc4",
> 0
>#ifndef MIN
>#define MIN(a,b) (((a) > (b)) ? (b) : (a))
>#endif
>#define USE_SHELL
>#ifdef USE_SHELL
>#include <rtems/shell.h>
>void fileio_start_shell(void)
> printf(" =========================\n");
> printf(" starting shell\n");
> shell_init("SHLL",0,100,"/dev/console",
> B9600 | CS8,
> 0);
> rtems_task_suspend(RTEMS_SELF);
>#endif /* USE_SHELL */
>void fileio_print_free_heap(void)
> printf("--- unused dynamic memory: %lu bytes ---\n",
> (unsigned long) malloc_free_space());
>void fileio_part_table_initialize(void)
> char devname[64];
> rtems_status_code rc;
> printf(" Initialize partition table\n");
> fileio_print_free_heap();
> printf(" Enter device to initialize ==>");
> fgets(devname,sizeof(devname)-1,stdin);
> while (devname[strlen(devname)-1] == '\n') {
> devname[strlen(devname)-1] = '\0';
> * call function
> rc = rtems_ide_part_table_initialize(devname);
> printf("result = %d\n",rc);
>void fileio_fsmount(void)
> printf(" Process fsmount table\n");
> * call function
> rc = rtems_fsmount( fs_table,
> sizeof(fs_table)/sizeof(fs_table[0]),
> NULL);
>void fileio_list_file(void)
> char fname[1024];
> char *buf_ptr = NULL;
> unsigned32 flen = 0;
> int fd = -1;
> ssize_t n;
> size_t buf_size = 100;
> rtems_interval start_tick,curr_tick,ticks_per_sec;
> printf(" LIST FILE ... \n");
> printf(" Enter filename to list ==>");
> fgets(fname,sizeof(fname)-1,stdin);
> while (fname[strlen(fname)-1] == '\n') {
> fname[strlen(fname)-1] = '\0';
> * allocate buffer of given size
> if (buf_size > 0) {
> buf_ptr = malloc(buf_size);
> if (buf_ptr != NULL) {
> printf("\n Trying to open file \"%s\" for read\n",fname);
> fd = open(fname,O_RDONLY);
> if (fd < 0) {
> printf("*** file open failed, errno = %d(%s)\n",errno,strerror(errno));
> if (fd >= 0) {
> rtems_clock_get (RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, &start_tick);
> do {
> n = read(fd,buf_ptr,buf_size);
> if (n > 0) {
> write(1,buf_ptr,n);
> flen += n;
> } while (n > 0);
> rtems_clock_get (RTEMS_CLOCK_GET_TICKS_SINCE_BOOT, &curr_tick);
> printf("\n ******** End of file reached, flen = %d\n",flen);
> close(fd);
> rtems_clock_get(RTEMS_CLOCK_GET_TICKS_PER_SECOND, &ticks_per_sec);
> printf("time elapsed for read: %g seconds\n",
> ((double)curr_tick-start_tick)/ticks_per_sec);
> * free buffer
> free(buf_ptr);
> * convert a size string (like 34K or 12M) to actual byte count
>boolean fileio_str2size(const char *str,unsigned32 *res_ptr)
> boolean failed = FALSE;
> unsigned long size;
> char suffix = ' ';
> if (1 > sscanf(str,"%lu%c",&size,&suffix)) {
> failed = TRUE;
> else if (toupper(suffix) == 'K') {
> size *= 1024;
> else if (toupper(suffix) == 'M') {
> size *= 1024UL*1024UL;
> else if (isalpha(suffix)) {
> failed = TRUE;
> if (!failed) {
> *res_ptr = size;
> return failed;
>void fileio_write_file(void)
> char fname[1024];
> char tmp_str[32];
> unsigned32 file_size = 0;
> unsigned32 buf_size = 0;
> size_t curr_pos,bytes_to_copy;
> int fd = -1;
> ssize_t n;
> char *bufptr = NULL;
> static const char write_test_string[] =
> "The quick brown fox jumps over the lazy dog\n";
> static const char write_block_string[] =
> "\n----- end of write buffer ------\n";
> printf(" WRITE FILE ... \n");
> * get number of ticks per second
> * get path to file to write
> if (!failed) {
> printf("Enter path/filename ==>");
> if (0 == strlen(fname)) {
> printf("*** no filename entered, aborted\n");
> failed = TRUE;
> * get total file size to write
> if (!failed) {
> printf("use suffix K for Kbytes, M for Mbytes or no suffix for bytes:\n"
> "Enter filesize to write ==>");
> fgets(tmp_str,sizeof(tmp_str)-1,stdin);
> failed = fileio_str2size(tmp_str,&file_size);
> if (failed) {
> printf("*** illegal file size, aborted\n");
> * get block size to write
> if (!failed) {
> "Enter block size to use for write calls ==>");
> failed = fileio_str2size(tmp_str,&buf_size);
> if (failed) {
> printf("*** illegal block size, aborted\n");
> * allocate buffer
> if (!failed) {
> printf("... allocating %lu bytes of buffer for write data\n",
> (unsigned long)buf_size);
> bufptr = malloc(buf_size+1); /* extra space for terminating NUL char */
> if (bufptr == NULL) {
> printf("*** malloc failed, aborted\n");
> failed = TRUE;
> * fill buffer with test pattern
> if (!failed) {
> printf("... filling buffer with write data\n");
> curr_pos = 0;
> * fill buffer with test string
> while (curr_pos < buf_size) {
> bytes_to_copy = MIN(buf_size-curr_pos,
> sizeof(write_test_string)-1);
> memcpy(bufptr+curr_pos,write_test_string,bytes_to_copy);
> curr_pos += bytes_to_copy;
> * put "end" mark at end of buffer
> bytes_to_copy = sizeof(write_block_string)-1;
> if (buf_size >= bytes_to_copy) {
> memcpy(bufptr+buf_size-bytes_to_copy,
> write_block_string,
> bytes_to_copy);
> * create file
> if (!failed) {
> printf("... creating file \"%s\"\n",fname);
> fd = open(fname,O_WRONLY | O_CREAT | O_TRUNC,S_IREAD|S_IWRITE);
> if (fd < 0) {
> printf("*** file create failed, errno = %d(%s)\n",errno,strerror(errno));
> failed = TRUE;
> * write file
> if (!failed) {
> printf("... writing to file\n");
> curr_pos = 0;
> do {
> bytes_to_copy = buf_size;
> do {
> n = write(fd,
> bufptr + (buf_size-bytes_to_copy),
> MIN(bytes_to_copy,file_size-curr_pos));
> if (n > 0) {
> bytes_to_copy -= n;
> curr_pos += n;
> } while ((bytes_to_copy > 0) && (n > 0));
> } while ((file_size > curr_pos) && (n > 0));
> if (n < 0) {
> failed = TRUE;
> printf("*** file write failed, "
> "%lu bytes written, "
> "errno = %d(%s)\n",
> (unsigned long)curr_pos,errno,strerror(errno));
> else {
> printf("time elapsed for write: %g seconds\n",
> printf("write data rate: %g KBytes/second\n",
> (((double)file_size) / 1024.0 /
> (((double)curr_tick-start_tick)/ticks_per_sec)));
> if (fd >= 0) {
> printf("... closing file\n");
> close(fd);
> if (bufptr != NULL) {
> printf("... deallocating buffer\n");
> free(bufptr);
> bufptr = NULL;
> printf("\n ******** End of file write\n");
>void fileio_read_file(void)
> char fname[1024];
> char tmp_str[32];
> size_t curr_pos;
> int fd = -1;
> ssize_t n;
> printf(" READ FILE ... \n");
> * get path to file to read
> if (!failed) {
> failed = TRUE;
> * get block size to read
> if (!failed) {
> "Enter block size to use for read calls ==>");
> if (failed) {
> * allocate buffer
> if (!failed) {
> failed = TRUE;
> * open file
> if (!failed) {
> printf("... opening file \"%s\"\n",fname);
> if (fd < 0) {
> failed = TRUE;
> * read file
> if (!failed) {
> printf("... reading from file\n");
> curr_pos = 0;
> do {
> n = read(fd,
> bufptr,
> buf_size);
> if (n > 0) {
> curr_pos += n;
> } while (n > 0);
> if (n < 0) {
> failed = TRUE;
> printf("*** file read failed, "
> "%lu bytes read, "
> "errno = %d(%s)\n",
> else {
> printf("%lu bytes read\n",
> (unsigned long)curr_pos);
> printf("read data rate: %g KBytes/second\n",
> (((double)curr_pos) / 1024.0 /
> if (fd >= 0) {
> close(fd);
> free(bufptr);
> bufptr = NULL;
> printf("\n ******** End of file read\n");
>void fileio_menu (void)
> char inbuf[10];
> * Wait for characters from console terminal
> for (;;) {
> printf(" RTEMS FILE I/O Test Menu \n");
> printf(" p -> part_table_initialize\n");
> printf(" f -> mount all disks in fs_table\n");
> printf(" l -> list file\n");
> printf(" r -> read file\n");
> printf(" w -> write file\n");
>#ifdef USE_SHELL
> printf(" s -> start shell\n");
>#endif
> printf(" Enter your selection ==>");
> inbuf[0] = '\0';
> fgets(inbuf,sizeof(inbuf),stdin);
> switch (inbuf[0]) {
> case 'l':
> fileio_list_file ();
> break;
> case 'r':
> fileio_read_file ();
> break;
> case 'w':
> fileio_write_file ();
> break;
> case 'p':
> fileio_part_table_initialize ();
> break;
> case 'f':
> fileio_fsmount ();
> break;
>#ifdef USE_SHELL
> case 's':
> fileio_start_shell ();
> break;
>#endif
> default:
> printf("Selection `%c` not implemented\n",inbuf[0]);
> break;
> exit (0);
>int menu_tid;
> * RTEMS Startup Task
>rtems_task
>Init (rtems_task_argument ignored)
> puts( "\n\n*** FILE I/O SAMPLE AND TEST ***" );
> fileio_menu();
Angelo Fraietta
PO Box 859
Hamilton NSW 2303
Home Page
http://www.users.bigpond.com/angelo_f/
There are those who seek knowledge for the sake of knowledge - that is CURIOSITY
There are those who seek knowledge to be known by others - that is VANITY
There are those who seek knowledge in order to serve - that is LOVE
Bernard of Clairvaux (1090 - 1153)
URL: <http://lists.rtems.org/pipermail/users/attachments/20030518/650a3faa/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.rtems.org/pipermail/users/attachments/20030518/650a3faa/attachment-0001.h>
