IDE support.
Joel Sherrill
joel.sherrill at OARcorp.com
Mon May 19 13:19:42 UTC 2003
"Eugeny S. Mints" wrote:
> Hi,
> On Sun, 18 May 2003, Chris Johns wrote:
> > Angelo Fraietta wrote:
> > > Chris Johns wrote:
> > >> Hell Angelo,
> > > It gets a bit like that sometimes
> > > The fsmount are the files needed to get the dsofs working.
> > Excellent.
> > > the init.c is the example that came with patch-- it is quite easy to
> > > understand
> > Which patch are you talking about ?
> > > To get it working for me, I included the fsmount into my project and
> > > added the functionality from init.c into my project.
> > > I have it working in my embedded target quite well.
> > This is good news.
> > I assume from the code being posted that I no other documentation exists ?
> > I have reviewed the documentation, but only as texinfo (cannot build it) and
> > could find nothing specific about using the DOSFS with IDE. Is this correct ?
> No, it isn't. Last documentation tarball contains ATA and
> IDE brief overview as two chapters in BSP and Device Drivers
> Development Guide.
http://www.rtems.com/rtems/doc-current/share/rtems/html/bsp_howto/index.html
> Bw,
> Eugeny
> Eugeny S. Mints
> OKTET Ltd.
> 1 Ulianovskaya st., Petergof, St.Petersburg, 198904 Russia
> Phone: +7(812)428-4384 Fax: +7(812)327-2246
> mailto:Eugeny.Mints at oktet.ru
