size_rtems:
Joel Sherrill
joel.sherrill at OARcorp.com
Tue May 20 13:03:20 UTC 2003
Bert wrote:
> Hi,all,
> i found a command "size_rtems" in the documnet
> <<RTEMS Development Environment Guide>>,
> it is useful, but i can not find it in the
> directory /opt/rtems/bin. why?
It has been broken by a number of improvements and
reorganizations in RTEMS. The first thing that broke
it was splitting managers into multiple files.
A better approach which I experimented with was to
use TARGET-ld with a specific list of undefined symbols
and see how large the resulting footprint was. But this
isn't really comparable to what size_rtems reported since
it ends up pulling in all of the core dependencies. For
example, if you did this with rtems_task_create and
rtems_task_delete, you would likely find that both results
appear about the same size and share a lot of dependencies.
Mark and I worked on the concept of example applications which
met what we felt was a common profile. This seems more
useful than "how large is function X?" The application profiles
were for a specific BSP included:
+ with and without POSIX enabled
+ samples/minimum
+ hello
+ ticker
+ networking with no servers (all networking used loopback)
+ ftpd
+ httpd
+ both ftpd and httpd
Size information is IMO largely bogus unless it is tailored to
your specific requirements. I thought the application profiles
were promising but never got a whole lot of feedback on them.
They required a fair amount of manual effort to compile.
--joel
> Bert
> Ãâ·ÑÍæÆ»¹ûÅÉÍøÂçÓÎÏ·£¬ÓÃ21CNÓÊÏä×¢²áËÍ²ÊÆÁÊÖ»ú¼°¼ÛÖµÊýÊ®ÍòµÄ¾«ÃÀ½±Æ·
> http://www.appie.com.cn
> Áô¸øÕŹúÈÙ×î°®µÄ˵»°
> http://sms.21cn.com/leslie/
> ½¡¿µÐÔ¹ÛÄîÏíÊÜÃÀÃîµÄʱ¿Ì
> http://sms.21cn.com/sexxy.jsp
> 21CN²ÊÐÅÓÊ£¬ÉùÉ«²ÊÐÅ£¬×ÔÓÉÊÕ·¢
> http://mail.21cn.com/huodong/0304/
> ÐÂÔöHTML±à¼Æ÷£¬ÁîÓʼþ¸ü³öÉ«
> http://mail.21cn.com/bijiao/02.html
joel at OARcorp.com On-Line Applications Research
