sync'ing (was Re: (Fwd) Re: DOSFS bug fixes, IDE drivers and sample released)
Chris Johns
cjohns at cybertec.com.au
Fri May 23 05:36:27 UTC 2003
Ralf Corsepius wrote:
> Am Fre, 2003-05-23 um 03.50 schrieb Chris Johns:
>>Should these calls also flush the user-space buffered (libc) data ?
> Good question, SUSv3 says:
> fsync - synchronize changes to a file
> int fsync(int fildes);
> DESCRIPTION:
> The fsync() function shall request that all data for the open
> file descriptor named by fildes is to be transferred to the
> storage device associated with the file described by fildes in
> an implementation-defined manner. The fsync() function shall not
> return until the system has completed that action or until an
> error is detected.
> I am not sure on how to interpret this, but I am inclined to read this
> as "fsync shall imply fflush".
I agree. It is safer and this has got to be better.
> Anyway, I think, the actual problem in Angelo's case is shutting down
> the "system too fast", before the fclose has completed (Assuming that
> "restartRtems" issues a shutdown/reboot or similar).
Agreed. If you call reboot, or let a watchdog reset go off then data can be lost.
> If this presumption is true, waiting for a couple of seconds before
> exiting the process rsp. issueing a "reboot/reset" should help.
> If this doesn't help, probably something in RTEMS's fclose or the
> fs-code underneath is broken.
I think fclose is ok, but I am concerned the FS API is not handling exit cleanly. I
cannot see any of the FS sync interface hooked to exit. What if some code called 'exit' ?
Maybe sync is added and then called in _exit.
Chris Johns, cjohns at cybertec . com . au
