unable to build eth_comm under CygWin
Victor V. Vengerov vvv at oktet.ru
Mon Nov 10 18:18:56 UTC 2003
Dieter,
Could you attach
/home/DiScha/rtems/rtems-build/build-ppc/powerpc-rtems/c/eth_comm
/exec/score/cpu/powerpc/Makefile
as well?
Regards,
Victor
Dieter Schaefer wrote:
><?xml  version="1.0" ?><html>
><head>
><title></title>
></head>
><body>
><div align="left"><font face="Arial"><span style="font-size:10pt">Hello,</span></font></div>
><div align="left"><br/>
></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">I try to build eth_comm from rtems-4.6.0pre5 under CygWin (1.5.3-1) </span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">on Win2K.</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">It fails with</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Makefile:745: *** missing separator.  Stop.</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">in directory</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">score/cpu/powerpc</span></font></div>
></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">The last part of the screen output is attached. The shell script </span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">to configure and make too.</span></font></div>
></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Interestingly, the build of mcf5206elite works Ok on CygWin.</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">On Linux(SuSE), the build of eth_comm and mcf5206elite are </span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Ok too.</span></font></div>
></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">What am I missing, or what did I do wrong?  </span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Any information or hint is appreciated.</span></font></div>
></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Thanks</span></font></div>
><div align="left"><font face="Arial"><span style="font-size:10pt">Dieter Schaefer</span></font></div>
><div align="left"><br/></div>
><div align="left"></div>
></body>
></html>
>-------------- Enclosure number 1 ----------------
> * This message contains the file 'build-rtems-ppc.log', which has been
> * uuencoded. If you are using Pegasus Mail, then you can use
> * the browser's eXtract function to lift the original contents
> * out to a file, otherwise you will have to extract the message
> * and uudecode it manually.
>-------------- Enclosure number 2 ----------------
>#!/bin/bash
>. ../RTEMS-Environment
>BLD_PATH=$BaseDir/build-ppc
>if [  -e $BLD_PATH ]; then rm -rf $BLD_PATH; fi
>if [ ! -e $BLD_PATH ]; then mkdir $BLD_PATH; fi
>cd $BLD_PATH
>$RTEMS_SS_PATH/configure \
>  --prefix=$INSTALL_PATH \
>  --enable-rtems-debug \
>  --enable-maintainer-mode \
>  --disable-itron \
>  --enable-cxx \
>  --enable-tests \
>  --target=powerpc-rtems \
>  --enable-rtemsbsp=eth_comm
>#  --enable-docs \
>make all #VARIANT=DEBUG
>#make install #VARIANT=DEBUG
Victor V. Vengerov
OKTET Ltd.
Ulianovskaya st., 1, office 533, St.-Petersburg 198504 Russia
phone: +7 812 4284384(work),+7 812 9389372(mobile),+7 812 4281653(home)
