UDP packet not sent
Rolf Schroedter Rolf.Schroedter at dlr.de
Wed Nov 12 06:19:38 UTC 2003
gregory.menke at gsfc.nasa.gov wrote:
> Ah, I see- thats a different problem.  In your udpclose function, you
> call the various rtems_ info functions.  If you call them before and
> after the packets are lost, are the lost packets being properly
> counted?
> Its not inconceivable theres a bug in the driver, but I would not
> suspect one in the IP stack itself.
Hallo Gregory,
unfortunately I'm not able to reply to you from home.
Your gsfcrelay4.gsfc.nasa.gov blocks my web.de
Here is the log with printed RTEMS network statistics
and marked lost packets (not shown in ETHEREAL).
BTW, my network configuration is simple:
- A Linux-PC and a LEON-board (RTEMS) connected with a crossed cable.
- No hub/switch
- Packets are sent very slowly with a 100 msec delay.
Log output:
My name is leon (192.168.0.100)
open_eth: driver attached, PHY config : 0x0000
UDP: Writing UDP packets to addr=192.168.0.1 port=50001 ...
=== #0 32 x 1040, 12 x 960 ===
write: bytes=0x20 size=1040 result=1040
write: bytes=0x21 size=1040 result=1040
write: bytes=0x22 size=1040 result=1040
write: bytes=0x23 size=1040 result=1040
write: bytes=0x24 size=1040 result=1040
write: bytes=0x25 size=1040 result=1040
write: bytes=0x26 size=1040 result=1040
write: bytes=0x27 size=1040 result=1040
write: bytes=0x28 size=1040 result=1040
write: bytes=0x29 size=1040 result=1040
write: bytes=0x2A size=1040 result=1040
write: bytes=0x2B size=1040 result=1040
write: bytes=0x2C size=1040 result=1040
write: bytes=0x2D size=1040 result=1040
write: bytes=0x2E size=1040 result=1040
write: bytes=0x2F size=1040 result=1040
write: bytes=0x30 size=1040 result=1040
write: bytes=0x31 size=1040 result=1040
write: bytes=0x32 size=1040 result=1040
write: bytes=0x33 size=1040 result=1040
write: bytes=0x34 size=1040 result=1040
write: bytes=0x35 size=1040 result=1040
write: bytes=0x36 size=1040 result=1040
write: bytes=0x37 size=1040 result=1040
write: bytes=0x38 size=1040 result=1040
write: bytes=0x39 size=1040 result=1040
write: bytes=0x3A size=1040 result=1040
write: bytes=0x3B size=1040 result=1040
write: bytes=0x3C size=1040 result=1040
write: bytes=0x3D size=1040 result=1040
write: bytes=0x3E size=1040 result=1040
write: bytes=0x3F size=1040 result=1040    ### all packets sent ###
************ MBUF STATISTICS ************
mbufs:1024    clusters: 128    free: 112
drops:   0       waits:   0  drains:   0
       free:1007          data:17          header:0           socket:0
        pcb:0           rtable:0           htable:0           atable:0
     soname:0           soopts:0           ftable:0           rights:0
     ifaddr:0          control:0          oobdata:0
************ INTERFACE STATISTICS ************
***** open_eth1 *****
Address:192.168.0.100   Broadcast Address:192.168.0.255
Flags: Up Broadcast Running Simplex
Send queue limit:50   length:0    Dropped:0
          Rx Packets:1             Rx Interrupts:1
Length:0              Non-octet:0
             Bad CRC:0                Overrun:0                   Miss:0
              Collision:0
       Tx Interrupts:0               Deferred:0        Missed Hearbeat:0
          No Carrier:0       Retransmit Limit:0         Late Collision:0
            Underrun:0        Raw output wait:0
************ IP Statistics ************
     total ip packets generated here          32
write: bytes=0x40 size=960 result=960    ### lost ###
write: bytes=0x41 size=960 result=960    ### lost ###
write: bytes=0x42 size=960 result=960    ### lost ###
write: bytes=0x43 size=960 result=960    ### lost ###
write: bytes=0x44 size=960 result=960    ### lost ###
write: bytes=0x45 size=960 result=960    ### lost ###
write: bytes=0x46 size=960 result=960    ### lost ###
write: bytes=0x47 size=960 result=960    ### lost ###
write: bytes=0x48 size=960 result=960    ### lost ###
write: bytes=0x49 size=960 result=960    ### lost ###
write: bytes=0x4A size=960 result=960    ### lost ###
write: bytes=0x4B size=960 result=960    ### lost ###
              Collision:0
     total ip packets generated here          44
write: bytes=0x4C size=480 result=480    ### lost ###
write: bytes=0x4D size=240 result=240
write: bytes=0x4E size=120 result=120
write: bytes=0x4F size=60 result=60
              Collision:0
     total ip packets generated here          48
=== #1 32 x 1040, 12 x 960 ===
write: bytes=0x50 size=1040 result=1040    ### lost ###
write: bytes=0x51 size=1040 result=1040    ### lost ###
write: bytes=0x52 size=1040 result=1040    ### lost ###
write: bytes=0x53 size=1040 result=1040    ### lost ###
write: bytes=0x54 size=1040 result=1040    ### lost ###
write: bytes=0x55 size=1040 result=1040    ### lost ###
write: bytes=0x56 size=1040 result=1040    ### lost ###
write: bytes=0x57 size=1040 result=1040    ### lost ###
write: bytes=0x58 size=1040 result=1040    ### lost ###
write: bytes=0x59 size=1040 result=1040    ### lost ###
write: bytes=0x5A size=1040 result=1040    ### lost ###
write: bytes=0x5B size=1040 result=1040    ### lost ###
write: bytes=0x5C size=1040 result=1040    ### lost ###
write: bytes=0x5D size=1040 result=1040
write: bytes=0x5E size=1040 result=1040
write: bytes=0x5F size=1040 result=1040
write: bytes=0x60 size=1040 result=1040    ### lost ###
write: bytes=0x61 size=1040 result=1040    ### lost ###
write: bytes=0x62 size=1040 result=1040    ### lost ###
write: bytes=0x63 size=1040 result=1040    ### lost ###
write: bytes=0x64 size=1040 result=1040    ### lost ###
write: bytes=0x65 size=1040 result=1040    ### lost ###
write: bytes=0x66 size=1040 result=1040    ### lost ###
write: bytes=0x67 size=1040 result=1040    ### lost ###
write: bytes=0x68 size=1040 result=1040    ### lost ###
write: bytes=0x69 size=1040 result=1040    ### lost ###
write: bytes=0x6A size=1040 result=1040    ### lost ###
write: bytes=0x6B size=1040 result=1040    ### lost ###
write: bytes=0x6C size=1040 result=1040    ### lost ###
write: bytes=0x6D size=1040 result=1040
write: bytes=0x6E size=1040 result=1040
write: bytes=0x6F size=1040 result=1040
              Collision:0
     total ip packets generated here          80
write: bytes=0x70 size=960 result=960    ### lost ###
write: bytes=0x71 size=960 result=960    ### lost ###
write: bytes=0x72 size=960 result=960    ### lost ###
write: bytes=0x73 size=960 result=960    ### lost ###
write: bytes=0x74 size=960 result=960    ### lost ###
write: bytes=0x75 size=960 result=960    ### lost ###
write: bytes=0x76 size=960 result=960    ### lost ###
write: bytes=0x77 size=960 result=960    ### lost ###
write: bytes=0x78 size=960 result=960    ### lost ###
write: bytes=0x79 size=960 result=960    ### lost ###
write: bytes=0x7A size=960 result=960    ### lost ###
write: bytes=0x7B size=960 result=960    ### lost ###
              Collision:0
     total ip packets generated here          92
write: bytes=0x7C size=480 result=480    ### lost ###
write: bytes=0x7D size=240 result=240
write: bytes=0x7E size=120 result=120
write: bytes=0x7F size=60 result=60
              Collision:0
     total ip packets generated here          96
packets sent: 64 x 1040, 24 x 960, 8 x 960/2^n  errors=0
UDP: Closing connection
