help gdb problems
Mon Nov 17 12:03:20 UTC 2003
You have to have a target with capital RTEMS -- i386-RTEMS.  I don't
think it is
prebuilt.  Also the internals of gdb have changed in some recent
versions enough
that the rdbg patch doesn't apply anymore.  The patch is included in the
source
RPM but not applied.  Someone needs to update it.
--joel
Rloase Flinne wrote:
> Hi there,
> I've built rtems 4.6.0pre5 successfully but have some trouble in
> debugging. Could anyone give any help?
> I followed the steps in rtems_gdb.pdf section 3 but failed at the first
> directive 'setrpcmode':
> (gdb)setrpcmode sun
> Undefined command: "setrpcmode".  Try "help".
> This is the info about my i386-rtems-gdb:
> (gdb) show version
> GNU gdb 5.2
> Copyright 2002 Free Software Foundation, Inc.
> GDB is free software, covered by the GNU General Public License, and
> you are
> welcome to change it and/or distribute copies of it under certain
> conditions.
> Type "show copying" to see the conditions.
> There is absolutely no warranty for GDB.  Type "show warranty" for
> details.
> This GDB was configured as "--host=i386-cygwin --target=i386-rtems".
> Any suggestion is appreciated.
> Rloase Flinne
