help gdb problems
Chuck Tuffli chuck_tuffli at agilent.com
Mon Nov 17 15:49:37 UTC 2003
I have modified gdb such that i386-RTEMS is a valid target. Running
this version of gdb accepts the 'setrpcmode' and other commands
mentioned in the GDB User's Guide. What I haven't been able to do is
create an application that connects to the debugger using rdbg. Anyone
have a simple application that can use remote debugging over the
network? If so, I could test my modifications and submit a patch.
---chuck
On Mon, Nov 17, 2003 at 06:03:20AM -0600, Joel Sherrill wrote:
> You have to have a target with capital RTEMS -- i386-RTEMS.  I don't
> think it is
> prebuilt.  Also the internals of gdb have changed in some recent
> versions enough
> that the rdbg patch doesn't apply anymore.  The patch is included in the
> source
> RPM but not applied.  Someone needs to update it.
> --joel
> Rloase Flinne wrote:
> >Hi there,
> >I've built rtems 4.6.0pre5 successfully but have some trouble in
> >debugging. Could anyone give any help?
> >I followed the steps in rtems_gdb.pdf section 3 but failed at the first
> >directive 'setrpcmode':
> >(gdb)setrpcmode sun
> >Undefined command: "setrpcmode".  Try "help".
> >This is the info about my i386-rtems-gdb:
> >(gdb) show version
> >GNU gdb 5.2
> >Copyright 2002 Free Software Foundation, Inc.
> >GDB is free software, covered by the GNU General Public License, and
> >you are
> >welcome to change it and/or distribute copies of it under certain
> >conditions.
> >Type "show copying" to see the conditions.
> >There is absolutely no warranty for GDB.  Type "show warranty" for
> >details.
> >This GDB was configured as "--host=i386-cygwin --target=i386-rtems".
> >Any suggestion is appreciated.
> >Rloase Flinne
Chuck Tuffli    <chuck_tuffli AT NO_SPAM agilent DOT com>
Agilent Technologies, Storage Area Networking
