Question to OAR
Dieter Schaefer Dieter.B.Schaefer at t-online.de
Mon Nov 17 20:18:57 UTC 2003
On 11 Nov 2003 at 18:22, Dieter Schaefer wrote:
> Hello,
> did the combination
>   powerpc-rtems/eth_comm
> build Ok on your site under CygWin?
> (rtems-4.6.0pre5 and associated tool-chain for CygWin)
> If yes, could you pls tell me your CygWin version and Operating
> System?
> If not, could you try to get it to work?
> Thanks
> Dieter Schaefer
unfortunately, I got no answer to my question.
My conclusion is that this combination was never tested.
Digging into that problem myself, I found the following:
* target=m68k-rtems, rtemsbsp=mcf5206elite
* target=arm-rtems, rtemsbsp=edb7312 + vegaplus
builds Ok, including tests
* powerpc-rtems, rtemsbsp=eth_comm + mbx8xx
fails to build.
Now, guess why ... If you need a hint, don't hesitate to ask ...
Of course, It's fixed now.
My recommendation is to establish some kind of "quality assurance"
procedure. Also add a list to every release/snapshot which explains
what has been tested and what not.
Like target=a, bsp=b has been successfully tested on real hardware
target=x, bsp=y have been build without errors, however not tested
on real hardware, etc.
I think, that could save people some time and possibly avoid chasing
a phantom.
Best regards
Dieter Schaefer
