stdint.h & machine/types.h Header file redefinitions
Derick Hammond
derick at perkinstechnologies.com.au
Wed Nov 19 04:10:10 UTC 2003
Hello All:
I have come up with a redefinition warning when I started using the
stdint.h header file.
A little background:
I use the multilib compiled version of the RTEMS libraries for m68k, and my
own build system that links to the appropriate libraries. Much like using
the AMX RTOS, or any commercial RTOS for that matter. :-)
The current warning that I get is:
/opt/rtems-4.6/bin/m68k-rtems-gcc -m5200 -O4 -fomit-frame-pointer -Wall -g
-ansi -fasm -DBOOTSTRAP
-I/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include
-I/home/derickh/cvs_wa/DataVault_Firmware/firmware/include
-I/home/derickh/cvs_wa/DataVault_Firmware/firmware/rom_start
-I/home/derickh/cvs_wa/DataVault_Firmware/firmware/startup -o
/home/derickh/cvs_wa/DataVault_Firmware/firmware/../library/rom_objs/rom_start/main.o
-c /home/derickh/cvs_wa/DataVault_Firmware/firmware/startup/main.c
In file included from
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/stdint.h:16,
from
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems/rtems/types.h:26,
from
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems.h:39,
from
/home/derickh/cvs_wa/DataVault_Firmware/firmware/include/tod/tod.h:33,
from
/home/derickh/cvs_wa/DataVault_Firmware/firmware/startup/main.c:32:
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems/stdint.h:21:
warning: redefinition of `int8_t'
/opt/rtems-4.6/m68k-rtems/include/machine/types.h:18: warning: `int8_t'
previously declared here
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems/stdint.h:22:
warning: redefinition of `int16_t'
/opt/rtems-4.6/m68k-rtems/include/machine/types.h:17: warning: `int16_t'
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems/stdint.h:23:
warning: redefinition of `int32_t'
/opt/rtems-4.6/m68k-rtems/include/machine/types.h:15: warning: `int32_t'
/home/derickh/cvs_wa/DataVault_Firmware/devtools/rtems/m68k-rtems/lib/include/rtems/stdint.h:24:
warning: redefinition of `int64_t'
/opt/rtems-4.6/m68k-rtems/include/machine/types.h:11: warning: `int64_t'
I have had a quick investigation and have found that machine/types.h seems
to only be used in cpukit/libnetworking. Is this correct? If so can
libnetworking be updated to use stdint.h instead?
I am happy to do a patch for rtems-4.6.0pre5 if I can get some feedback on
what would be considered the best way to solve this issue.
Thanks in advance.
Regards,
Derick Hammond
