more bsp question (was Bsp and CPU porting )
Feng, Shuchen
feng at bnl.gov
Wed Nov 19 18:23:41 UTC 2003
On Wed, 5 Nov 2003 10:13:03 -0600 Jay Monkman wrote :
>Did you add your CPU to libcpu/sh/configure.ac and your BSP to
>libbsp/sh/acinclude.m4? After modifying those files, you need to run
>bootstrap.
>Before running bootstrap, make sure you have the right versions of
automake
>and autoconf. Then, while in the libcpu/sh and libbsp/sh directories,
>run '../../../../../bootstrap -c' and '../../../../../bootstrap'
I installed the autoconf-2.57 and automake-1.7.6 on my RedaHat 7.3,
which I got from the RTEMS site. The RTEMS release is the
rtems-4.6.0pre3.
It seems that it went fine (no message) with the libcpu/powerpc.
However, '../../../../../bootstrap' only ran through the original BSP
even though, in the libbsp/powerpc/acinclude.m4, I had added :
mvme5500 )
AC_CONFIG_SUBDIRS([mvme5500]);;
Not knowing where RTEMS_BSP_FAMILY is defined.
I (blindly) added "RTEMS_BSP_FAMILY + = mvme5500"
in the libbsp/powerpc/Makefile.am so that
bootstrap can see it. However, it seems that it does not make a
difference. I still got the same error message :
gmake[6]: Entering directory
`/usr/local/source/newRTEMS/build/ppc-rtems/c/mvme5500/exec'
gmake[6]: Nothing to be done for `preinstall-am'.
gmake[6]: Leaving directory
Making preinstall in include
`/usr/local/source/newRTEMS/build/ppc-rtems/c/mvme5500/exec/include'
../../../../../../rtems-4.6.0pre3/c/src/../../cpukit/[]/mkinstalldirs:
No such file or directory
gmake[6]: *** [../../../../mvme5500/lib/include] Error 127
gmake[5]: *** [preinstall-recursive] Error 1
gmake[5]: Leaving directory
gmake[4]: *** [preinstall-recursive] Error 1
gmake[4]: Leaving directory
`/usr/local/source/newRTEMS/build/ppc-rtems/c/mvme5500'
gmake[3]: *** [preinstall-stamp] Error 2
gmake[3]: Leaving directory
gmake[2]: *** [all-recursive] Error 1
gmake[2]: Leaving directory
gmake[1]: *** [all-recursive] Error 1
gmake[1]: Leaving directory
`/usr/local/source/newRTEMS/build/ppc-rtems/c'
gmake: *** [all-recursive] Error 1
Did I miss any step ?
Thanks in advance,
Kate
