Makefiles for multi-directory applications
Ralf Corsepius corsepiu at faw.uni-ulm.de
Thu Nov 20 15:52:18 UTC 2003
On Thu, 2003-11-20 at 16:27, Alan Cudmore wrote:
> I have used the makefiles for RTEMS applications and demos for simple apps
> with a handful of C files in one directory.
IMO, you should reconsider this decision :-(
> Now I would like to create makefiles for an application with multiple
> levels of directories.
> In my directory tree, the make file calls other makefiles in
> sub-directories and compiles the C files for each sub-system ( or task ).
> When it gets to the part of the directory tree with the RTEMS startup code,
> that is where I would like to link it into an executable.
> What rules do I use in a subsystem makefile to just compile C files into
> objects ( and not try to link or create an application? )
> Is there an example of a multi-directory build like this?
RTEMS-3.x.x and may-be RTEMS-4.0.0 had used them this way.
> I want to take advantage of the RTEMS_MAKEFILE_PATH and the makefile
> includes for portability.
Err, ... these files are highly non-portable ... If I had to decide,
these files would have been removed years ago.
>  I can easily see what settings the RTEMS makefile
> is using and put them in my own makefile, but then it would have to be set
> for each RTEMS target..
I would not want to do what you are trying.
I'd recommend you to write normal Makefiles as you would do for
non-RTEMS applications and use them.
Ralf
