UDP packet not sent
gregory.menke at gsfc.nasa.gov
Tue Nov 11 17:45:35 UTC 2003
Rolf Schroedter writes:
> Hi Gregory,
> thanks for your answer, see my remarks below.
> gregory.menke at gsfc.nasa.gov wrote:
> > UDP is free to drop your packet at any time, including the sending and
> > receiving stack. The sendto() return != -1 indicates only that the
> > stack accepted your packet. This is true for all stacks. That said,
<snip>
> > features for reliable file delivery as well as messaging all over UDP.
> > Its one example at least...
> In my *real application* I'm doing an ACK/RETRY.
> The problem is that after sending a lot of 1040 byte packets
> even *all retries* of the 960 byte packet are dropped.
> Only after sending a smaller (240 byte) packet sending "somehow"
> continues, but now with most packets dropped.
> Obviously with this behaviour any ACK/RETRY regime will stuck.
> The question is, whether this is a general (RTEMS-IP) problem
> or a OPEN_ETH driver bug ?
> I'm attaching send a small sample UDP-writer application
> illustrating the problem.
Ah, I see- thats a different problem. In your udpclose function, you
call the various rtems_ info functions. If you call them before and
after the packets are lost, are the lost packets being properly
counted?
Its not inconceivable theres a bug in the driver, but I would not
suspect one in the IP stack itself.
Gregm
