Gdb Over Serial
gregory.menke at gsfc.nasa.gov
Tue Nov 11 22:30:01 UTC 2003
Chris Johns writes:
> gregory.menke at gsfc.nasa.gov wrote:
> > I don't think copying around vector tables is the right sort of thing
> > to be doing- perhaps you're trying to set it up too early in the RTEMS
> > boot process?
> If the interrupts are masked and during startup or exit I think it is
> valid to move a vector table. This could be a copy or a change in the
> VBR. I would not exclude doing it as a rule.
I wouldn't either, but a gdb stub usually only needs a vector for the
break and/or single step interrupt/exception. The stub handles all
the per-thread stuff itself. Perhaps I misunderstand what the OP
means wrt table copying...
Gregm
