netdemo
Eric Norum
norume at aps.anl.gov
Wed Nov 12 14:31:00 UTC 2003
aling wrote:
> I use "netdemo" to test the network driver.
> In test.c,there is:
> #define DATA_SINK_HOST ((128 < < 24) | (233 < < 16) | (14 < < 8) | 60)
> static void
> transmitTcp(void)
> farAddr.sin_family = AF_INET;
> farAddr.sin_port = htons (9); /* The `discard' port */
> farAddr.sin_addr.s_addr = htonl (DATA_SINK_HOST);
> printf ("Connect socket.\n");
> if (connect (s, (struct sockaddr *)&farAddr, sizeof farAddr) < 0) {
> printf ("Can't connect socket: %s\n", strerror (errno));
> close (s);
> return;
> At first,I didn't change them and ran them.When I typed 't',the following information was on the target console .
> "t
> Create socket.
> Bind socket.
> Connect socket.
> Can't connect socket: Connection timed out
> Then , I changed "#define DATA_SINK_HOST ((128 < < 24) | (233 < < 16) | (14 < < 8) | 60)" into
> "#define DATA_SINK_HOST ((192 < < 24) | (168 < < 16) | (1 < < 8) | 30)".
> The IP address of my host is 192.168.1.30.
> the output information:
> "t
> Create socket.
> Bind socket.
> Connect socket.
> Can't connect socket: Connection rejected.
> I am anxious to get your help.
Your target machine (192.168.1.30) isn't listening on the TCP 'discard' port (9). This is the way machines are often shipped nowadays as a security policy (don't turn on a service unless it is really needed). To get the test program working you'll need to figure out how to turn on this service on the target machine.
Eric Norum norume at aps.anl.gov
Advanced Photon Source Phone: (630) 252-4793
Argonne National Laboratory
