OpenSSL ported?
Camilo Alejandro Arboleda CamiloAlejo at netscape.net
Fri Nov 14 20:11:08 UTC 2003
Hi,
There is a 'generic' target also. It works fine if you replace 'gcc' by
'm68k-rtems-gcc', 'g++' with 'm68k-rtems-g++' and so on.
You are going to need some hacking in the Makefile.in files to remove
some targets you don't need (and can not build) like CLI tools.
I remember it took less than a day to acomplish the task, but I didn't
use it at the end, so I don't have the final configuration I used.
jonas.moberg at solidsoftware.net wrote:
>Has anybody ported or attempted  to port OpenSSL to rtems. As there is a BSD
>target this should be feasable. My target is a Coldfire board so I guess
>that the BSD
>-m68k configuration should be pretty close.
>Solid Software AB
>Jonas Moberg
Your favorite stores, helpful shopping tools and great gift ideas.
Experience the convenience of buying online with Shop at Netscape!
http://shopnow.netscape.com/
