Question to OAR
Dieter Schaefer Dieter.B.Schaefer at t-online.de
Wed Nov 19 08:40:09 UTC 2003
> Nevertheless, I can't reproduce your problem with make-3.80 under Linux.
> Another thought: Do you have an environment variable called LIB set?
> I recall some people using Cygwin had been suffering from problems
> related to having conflicts with environment variables.
> If yes, unset it and try again.
that works ... using
LIB=; export LIB
in my shell script, RTEMS + Tests are build Ok now.
BTW, I've also modified PATH to remove entries to M$$ like
/cygdrive/d/Programme/Microsoft Visual Studio/Common/Tools/WinNT
etc. However, this didn't solve the problem.
> Is make-3.79* available for Cygwin? If yes, would you please try this
> with unmodified RTEMS sources.
I didn't find one.
> Anyway, these Makefile.am need to be improved.
> Ralf
Dieter Schaefer
