Static section initializing
Leon Pollak
leonp at plris.com
Tue Nov 25 16:17:26 UTC 2003
On Tuesday 25 November 2003 18:06, Ralf Corsepius wrote:
> On Tue, 2003-11-25 at 16:46, Leon Pollak wrote:
> > On Tuesday 25 November 2003 18:03, gregory.menke at gsfc.nasa.gov wrote:
> > > IIRC, _init is empty because you don't have quite the right set of
> > > system libraries in your link script. I think you need to include the
> > > crtbegin, crtend- which gcc generates. Look at the motorola_shared
> > > bsp's link script- last time I used C++ in RTEMS it handled the
> > > constructors properly.
> > Gregory, thanks for the hint, but I have something wrong:
> > In my gcc installation (which was downloaded from the RTEMS site
> > powerpc-rtems-gcc (GCC) 3.2.2 (OAR Corporation
> > gcc-3.2.2-20030326/newlib-1.11.0-20030326-2)
> > there are files like crtbegin.o, but they do not contain any _init/_fini
> > symbols. Contrary, there are ecrti.o files which do contain _init/_fini,
> > but these are empty (I made objdump -s).
> > Do you have any idea where the working _init resides?
> They should have been produced by the compiler.
> Are you sure to be using 'g++' to *link*? You must use 'g++' instead of
> 'gcc' or 'ld' to *link* c++ applications.
> What you describe, matches the symptoms of using gcc to link.
> Ralf
OK, if such a high qualified person as Ralf does not know the answer
immediately, I am calm - the problem is not the result of my stupidity...:-))
No, Ralf, the linker is called as following:
powerpc-rtems-g++ -o DTC_DEBUG
-B/opt/rtems/rtems-bin/powerpc-rtems/FDR_GEN/lib/ -specs bsp_specs -mcpu=860
-Dmpc860 -qrtems -qrtems_debug -Wno-unused -ggdb -g -Wall -fasm -qnolinkcmds
-T linkcmds -Xlinker -Map -Xlinker map.map __AND_MY_OBJ_FILES_LIST__
But why do you think that this is linker problem, when I do not see
_init/_fini code in gcc files?
Leon Pollak
leonp at plris dot com
