Timeslicing question
Kamen Penev kamen at penev.net
Fri Oct 3 00:34:59 UTC 2003
Kenneth Peters wrote:
> Ugh. Thanks for the quick reply. This is ugly, though, if I have to go
> through and retrofit my task functions to the POSIX API.
It is not that much work really. Follow the example that I gave at the
end of the second thread. You don't have to change all your tasks to
POSIX. Only the ones that need SCHED_RR. And you can still use classic
semaphores, message queues etc. inside them.
> Joel indicated maybe the pthread_setschedparam() function could be
> called on a Classic API task to tweak the budget_algorithm parameter.
> If that value is really the only thing I need to change, that would be
> a better way for me. Has anyone tried that?
It didn't work for me back then, as reported in:
http://www.rtems.com/ml/rtems-users/2003/may/msg00158.html
The bug may have been fixed, I don't know. Try pthread_setschedparam and
see what happens.
Kamen
