cpukit Libraries install problem
Cedric Aubert cedric_aubert at yahoo.fr
Fri Oct 3 12:34:15 UTC 2003
--- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
wrote:
> Hi Cederic,
> > I want to use the termios_printk feature, witch is
> > provided in the serdbg. I don't found it in my
> > libmisc.a, even if I already found capture and
> untar
> > for example.
> > Any idea ?
> I should have, because this code is from me ;-)
> It was integrated into the source tree, but Joel
> experienced
> some problems with the pc386 BSP some time ago, so
> maybe it is
> not included into librtemscpu.a now.
> I used it recently without problems, the easiest way
> to use it
> for you would be to add its sources to your
> apllication make
> environment.
Ok thanks, so I will make some symbolic link for now !
I don't do this because I will want to have a more
clean solution.
Thanks
> Please be aware that the port you want to use with
> termios_printk MUST be configured to work in polled
> mode (not
> interrupt driven).
Ooops, I use a interrupt driven termios drivers :-(
But I read some of the code and I don't understand
what will be the problem....
If the serial Isr_Handler is correctly coded, it
shouldn't have problem.
Thanks
Cedric
> wkr,
> 	Thomas.
> > Thanks
> > Cedric
> > --- Thomas Doerfler
> > wrote:
> > > Hi Cederic,
> > > the list of libs has been reduced in one of the
> > > recent version steps, so the functions of
> > > libmisc.a should now be included in
> librtemscpu.a
> > > ( I think).
> > > wkr,
> > > 	Thomas.
> > > > Hi all,
> > > > I have some trouble to use the libmisc or
> other
> > > > cpukit libraries in my user application.
> (Can't
> > > link)
> > > > So I search in my bsp lib and rtems cpu shared
> lib
> > > and
> > > > don't found libmisc.a but I found it in my
> build
> > > > directory.
> > > > I have /opt/rtems/mybsp (I move my prefix at
> > > configure
> > > > here)
> > > > I have build in /opt/rtems/build (it's were I
> > > found
> > > > the
> > > > lib).
> > > > I should make a very very begimmer mistake :-)
> > > > Because I try to find the solution on the ml
> > > archive,
> > > > I don't found anything.
> > > > If anyone could explain me how to correctly
> > > install
> > > > those cpukit libraries.
> > > > I link with -B /opt/rtems/m68k-rtems/lib
> > > > -B
> /opt/rtems/bsp-cpu2000/m68k-rtems/cpu2000/lib
> > > > -B /opt/rtems/bsp-cpu2000/m68k-rtems/lib
> > > > But libmisc.a was found in
./build-m68k/m68k-rtems/cpukit/libmisc/wrapup/o-optimize/libmisc.a
./build-m68k/m68k-rtems/m68000/cpukit/libmisc/wrapup/o-optimize/libmisc.a
> > > > Thanks a lot
> > > > Cedric
> > > > __________________________________
> > > > Do you Yahoo!?
> > > > The New Yahoo! Shopping - with improved
> product
> > > search
> > > > http://shopping.yahoo.com
> > > IMD Ingenieurbuero fuer Microcomputertechnik
> > > Thomas Doerfler           Herbststrasse 8
> > > D-82178 Puchheim          Germany
> > > email:    Thomas.Doerfler at imd-systems.de
> > > PGP public key available at: http://www.imd-
> > > systems.de/pgp_keys.htm
> > Do you Yahoo!?
> > The New Yahoo! Shopping - with improved product
> search
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
