cpukit Libraries install problem (correction of my mistake !! :-)
Cedric Aubert cedric_aubert at yahoo.fr
Fri Oct 3 12:47:33 UTC 2003
--- Cedric Aubert <cedric_aubert at yahoo.fr> wrote:
> --- Thomas Doerfler <Thomas.Doerfler at imd-systems.de>
> wrote:
> > Hi Cederic,
> > > I want to use the termios_printk feature, witch
> is
> > > provided in the serdbg. I don't found it in my
> > > libmisc.a, even if I already found capture and
> > untar
> > > for example.
> > > Any idea ?
> > I should have, because this code is from me ;-)
> > It was integrated into the source tree, but Joel
> > experienced
> > some problems with the pc386 BSP some time ago, so
> > maybe it is
> > not included into librtemscpu.a now.
> > I used it recently without problems, the easiest
> way
> > to use it
> > for you would be to add its sources to your
> > apllication make
> > environment.
> Ok thanks, so I will make some symbolic link for now
> I don't do this because I will want to have a more
> clean solution.
> Thanks
> > Please be aware that the port you want to use with
> > termios_printk MUST be configured to work in
> polled
> > mode (not
> > interrupt driven).
> Ooops, I use a interrupt driven termios drivers :-(
> But I read some of the code and I don't understand
> what will be the problem....
> If the serial Isr_Handler is correctly coded,
diff -purN Answer1 Answer2
--- Answer1	Last 5 minutes
+++ Answer2     Now
@@ Stupid, Answer @@
- it shouldn't have problem.
+ you will still have problem, deviceWritePolled is
+ not avaible via termios Callbacks.
Sorry !! :-)
> Thanks
> Cedric
> > wkr,
> > 	Thomas.
> > > Thanks
> > > Cedric
> > > --- Thomas Doerfler
> > > wrote:
> > > > Hi Cederic,
> > > > the list of libs has been reduced in one of
> the
> > > > recent version steps, so the functions of
> > > > libmisc.a should now be included in
> > librtemscpu.a
> > > > ( I think).
> > > > wkr,
> > > > 	Thomas.
> > > > > Hi all,
> > > > > I have some trouble to use the libmisc or
> > other
> > > > > cpukit libraries in my user application.
> > (Can't
> > > > link)
> > > > > So I search in my bsp lib and rtems cpu
> shared
> > lib
> > > > and
> > > > > don't found libmisc.a but I found it in my
> > build
> > > > > directory.
> > > > > I have /opt/rtems/mybsp (I move my prefix at
> > > > configure
> > > > > here)
> > > > > I have build in /opt/rtems/build (it's were
> I
> > > > found
> > > > > the
> > > > > lib).
> > > > > I should make a very very begimmer mistake
> > > > > Because I try to find the solution on the ml
> > > > archive,
> > > > > I don't found anything.
> > > > > If anyone could explain me how to correctly
> > > > install
> > > > > those cpukit libraries.
> > > > > I link with -B /opt/rtems/m68k-rtems/lib
> > > > > -B
> > /opt/rtems/bsp-cpu2000/m68k-rtems/cpu2000/lib
> > > > > -B /opt/rtems/bsp-cpu2000/m68k-rtems/lib
> > > > > But libmisc.a was found in
./build-m68k/m68k-rtems/cpukit/libmisc/wrapup/o-optimize/libmisc.a
./build-m68k/m68k-rtems/m68000/cpukit/libmisc/wrapup/o-optimize/libmisc.a
> > > > > Thanks a lot
> > > > > Cedric
> > > > > __________________________________
> > > > > Do you Yahoo!?
> > > > > The New Yahoo! Shopping - with improved
> > product
> > > > search
> > > > > http://shopping.yahoo.com
> > > > IMD Ingenieurbuero fuer Microcomputertechnik
> > > > Thomas Doerfler           Herbststrasse 8
> > > > D-82178 Puchheim          Germany
> > > > email:    Thomas.Doerfler at imd-systems.de
> > > > PGP public key available at: http://www.imd-
> > > > systems.de/pgp_keys.htm
> > > Do you Yahoo!?
> > > The New Yahoo! Shopping - with improved product
> > search
> Do you Yahoo!?
> search
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
