More heap corruption / allocator lock problems
Till Straumann strauman at SLAC.Stanford.EDU
Tue Oct 7 17:39:55 UTC 2003
Hi all.
Paranoia pays off.
Today, (thanks to the paranoia check added to PR#504)
I found one more place where a CORE_mutex (the allocator
lock) is acquired from a dispatching-disabled code section:
The task-variable destructor hook (used e.g. by the rtems_shell
and 'libc userenv')!
Since it is run as part of a user extension's delete
hook/callback, the task variable destructor runs with
dispatching disabled :-(
Two solutions come to my mind:
a) memory that is going to be released by a task-variable
    destructor must be allocated from the workspace
b) free could be enhanced:
    if 'free' is called while _Thread_Dispatch_disable_level > 0,
    it sends its pointer argument to a special "gc" thread which
    will eventually execute the real 'free'. The synchronization
    mechanism *must* be nonblocking, of course, to avoid the
    same kind of problem...
While I feel that b) is 'hackish', it could certainly provide
backwards compatibility...
RFC
-- Till
