Local IP address
Richard M. Barry R.Barry at sstl.co.uk
Mon Oct 20 12:19:04 UTC 2003
Thomas,
I tried your code, but I get a compiler error: "sizeof applied to an incomplete type" for the rtems_bsdnet_config() line.
Richard
	-----Original Message-----
	From: Thomas Rauscher [mailto:trauscher at loytec.com]
	Sent: Mon 20/10/2003 11:23
	To: Richard M. Barry; rtems-users at rtems.com
	Cc:
	Subject: RE: Local IP address
	> From: Richard M. Barry [mailto:R.Barry at sstl.co.uk]
	> Sent: Monday, October 20, 2003 11:16 AM
	> To: rtems-users at rtems.com
	> Subject: Local IP address
	> How can I get the local IP address (the server's address, not
	> the client's) in a server I'm running?  I want to do this
	> before any connections are made from a client.
	> Richard
	The following code should do it.
	You just have to provide the correct interface name.
	  struct sockaddr_in addr;
	  rtems_bsdnet_ifconfig("eth0", SIOCGIFADDR, &addr);
	The IP address is then in addr.sin_addr.s_addr .
	Best regards,
	Thomas Rauscher
	Dipl.-Ing. Thomas Rauscher                 Tel.:   ++43 1 402 08 05 15
	                                           Fax:    ++43 1 402 08 05 99
	LOYTEC electronics GmbH                    E-mail: trauscher at loytec.com
	Stolzenthalergasse 24/3, A-1080 Wien       Web:    http://www.loytec.com
