Problem Building mcf5206elite BSP under Cygwin
Steve Strobel
steve at link-comm.com
Thu Oct 30 00:11:21 UTC 2003
I am having trouble building the mcf5206elite BSP under Cygwin. I had
trouble building it with 4.6.0pre4 a week or so ago, then had to take a
break to work on a different project. 4.6.0pre5 was released in the
meantime, so when I got to come back to this project, I downloaded the
new tools and RTEMS source and started over. I installed everything with
the following script:
#!/bin/sh
cd /
mkdir rtems
cd rtems
tar -xjf /temp/rtems-4.6.0pre5.tar.bz2
tar -xjf /temp/examples-4.6.0pre5.tar.bz2
tar -xjf /temp/network-demos-4.6.0pre5.tar.bz2
cd /
tar -xjf /temp/rtems-4.6-autoconf-rtems-2.57-1.tar.bz2
tar -xjf /temp/rtems-4.6-automake-rtems-1.7.2-1.tar.bz2
tar -xjf /temp/rtems-4.6-m68k-rtems-binutils-2.13.2.1-1.tar.bz2
tar -xjf /temp/rtems-4.6-m68k-rtems-c++-gcc3.2.3newlib1.11.0-1.tar.bz2
tar -xjf /temp/rtems-4.6-m68k-rtems-gcc-gcc3.2.3newlib1.11.0-1.tar.bz2
tar -xjf /temp/rtems-4.6-m68k-rtems-gdb-5.2-1.tar.bz2
tar -xjf /temp/rtems-4.6-rtems-base-binutils-2.13.2.1-1.tar.bz2
tar -xjf /temp/rtems-4.6-rtems-base-gcc-gcc3.2.3newlib1.11.0-1..tar.bz2
tar -xjf /temp/rtems-4.6-rtems-base-gdb-5.2-1.tar.bz2
Then, following the Getting Started guide, I...
Set the path to the tools:
export PATH=$PATH:/opt/rtems-4.6/bin
Tested the tool installation (this worked fine):
m68k-rtems-gcc -v -S f.c
m68k-rtems-gcc -v -c f.c
Made a build directory and tried to configure RTEMS:
cd /rtems
mkdir build-4.6.0pre5
cd build-4.6.0pre5
../rtems-4.6.0pre5/configure --target=m68k-rtems \
--disable-posix --disable-networking \
--disable-cxx --enable-rtemsbsp=mcf5206elite \
--prefix=/opt/rtems-4.6/bin
It appeared to finish successfully, so I ran "make all". It
ran for a while, but failed as follows:
configure: configuring in libcsupport
configure: running /bin/bash '../../../../../../rtems-4.6.0pre5/c/src/../../cpuk
it/libcsupport/configure' --prefix=/opt/rtems-4.6/bin '--prefix=/opt/rtems-4.6/
bin' '--host=m68k-rtems' '--build=i686-pc-cygwin' '--target=m68k-rtems' '--disab
le-posix' '--disable-networking' '--disable-cxx' '--with-target-subdir=m68k-rtem
s' '--exec-prefix=/opt/rtems-4.6/bin/m68k-rtems' 'build_alias=i686-pc-cygwin' 'h
ost_alias=m68k-rtems' 'target_alias=m68k-rtems' 'RTEMS_BSP=mcf5206elite' 'RTEMS_
CPU_MODEL=mcf5206' 'RTEMS_BSP_FAMILY=mcf5206elite' 'CPU_CFLAGS=-m5200' 'CFLAGS_O
PTIMIZE_V=-O4 -fomit-frame-pointer' '--with-project-root=../../' '--enable-rtems
bsp=mcf5206elite' '--cache-file=/dev/null' '--srcdir=../../../../../rtems-4.6.0p
re5/c/src/../../cpukit' --cache-file=/dev/null --srcdir=../../../../../../rtems-
4.6.0pre5/c/src/../../cpukit/libcsupport
configure: error: invalid variable name: build_alias
configure: error: /bin/bash '../../../../../../rtems-4.6.0pre5/c/src/../../cpuki
t/libcsupport/configure' failed for libcsupport
configure: error: /bin/bash '../../../../../rtems-4.6.0pre5/c/src/../../cpukit/c
onfigure' failed for ../../cpukit
make[2]: *** [mcf5206elite] Error 1
make[2]: Leaving directory `/rtems/build-4.6.0pre5/m68k-rtems/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/rtems/build-4.6.0pre5/m68k-rtems/c'
make: *** [all-recursive] Error 1
At that time, the libcsupport directory (C:\cygwin\rtems\build-4.6.0pre5\m68k-rtems\c\mcf5206elite\exec\libcsupport) was empty.
In other directories, the file config.log has a line like the following
build_alias='i686-pc-cygwin'
and makefile has
build_alias = i686-pc-cygwin
I tried to dig through the
'../../../../../../rtems-4.6.0pre5/c/src/../../cpukit/libcsupport/configure'
file and the configure.ac file that it comes from but I don't understand it well
enough to figure out what the problem with build-alias might be.
I then created a different build directory and tried a less complex configure
command, as follows:
make RTEMS_BSP=mcf5206elite
It failed in exactly the same way. I am missing a step or doing something wrong?
Does my cygwin setup have a problem? Any other ideas? Thanks for any help
you can give me.
Steve
Steve Strobel WWW: http://www.link-comm.com
Link Communications, Inc. Phone: (406) 245-5002 ext 102
MailTo:steve at link-comm.com Fax: (406) 245-4889
