mcf5206 - interrupt level
Cedric Aubert
cedric_aubert at yahoo.fr
Wed Oct 8 11:54:57 UTC 2003
Hi Stan,
To my mind, it's depend on your need. But the
timer IT should be the upper that the board can.
For example, if the more important thing for your
board is Datation, timer IT should be better that
Uart, but if your board primary goal is Uart
communication, you should put Uart IT better than
the Timer IT.
In fact the timer as I can say with what I see, it's
usefull datation or time sharing or delay but the
preemptivity of the kernel don't depend of it so
your usage should answer your question.
Hope that's help.
Cedric
--- Stan <zylog at club-internet.fr> wrote:
> hi,
> I need to intercept four external interrupts (two
> ethernet controler, power
> fail and modem dcd).
> Rtems use Timer1, Timer2, Mbus, Uart1 and Uart2
> internal interrupts.
> What should be timer1 level (timer1 call
> rtems_clock_tick directive) ?
> Is Timer1 ISR level important ?
> It should be greater or lower other interrupts level
> Thanks a lot.
> Stan.
AUBERT Cedric
SDEL Controle Commande
rue Nungesser & Coli
44860 St Aignan de Grand Lieu
E-mail : cedric_aubert at yahoo.fr
Http : http://www.controle-commande.sdel.fr/
__________________________________
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
http://shopping.yahoo.com
