[mcf5206] trap #15
Chris Johns cjohns at cybertec.com.au
Sat Oct 11 00:37:48 UTC 2003
Stan wrote:
> My application is interrupt by trap #15.
> When it can generate ?
Are you using a standard RTEMS compiler and libc ?
> I suppose libc can use that, but in which circumstance ?
I think the dbug monitor found on the Motoroal eval boards uses trap #15
as an entry point. Maybe your code is setup to call the dbug monitor.
  Chris Johns, cjohns at cybertec.com.au
