Multiple rtems_io_register_name
Thu Oct 23 10:59:35 UTC 2003
Cedric Aubert wrote:
>Thanks ralf,
>I agree with you, if very bad to do this,
>shame on me !:-(
>But it's for my high level application to be portable
>with two RTOS, RTEMS the new one and the older that
>use for io device name some /term1 /term2 ....
One minor note is that the default filesystem is the mini-IMFS which
is ONLY supports device nodes and directories.  So if you stick
with that filesystem as the root one in your application, you have
to create two device nodes per device.
Define CONFIGURE_USE_IMFS_AS_BASE_FILESYSTEM
before including confdefs.h to get the full IMFS with symlinks.
>I will try this, thanks everyone to have answer me :-)
>Cedric
>--- Ralf Corsepius <corsepiu at faw.uni-ulm.de> wrote:
>>On Thu, 2003-10-23 at 09:56, Cedric Aubert wrote:
>>>Another related question, is it mandatory to the
>>>symlink to be in the /dev directory ?
>>Well, not strictly as far as RTEMS is concerned, ie.
>>RTEMS doesn't
>>necessarily force you to do this.
>>However  I'd strongly encourage you to do so,
>>because it is common
>>standard to have all devices under /dev and because
>>this mandated for
>>some devices by POSIX/IEEE.
>>>Example :
>>>symlink ("/dev/porta", "/term0")
>>IMO, a bad idea ;)
>>Ralf
>AUBERT Cedric
>SDEL Controle Commande
>rue Nungesser & Coli
>44860 St Aignan de Grand Lieu
>E-mail : cedric_aubert at yahoo.fr
>Http : http://www.controle-commande.sdel.fr/
>__________________________________
>Do you Yahoo!?
>The New Yahoo! Shopping - with improved product search
>http://shopping.yahoo.com
