passing -D's through configure
Harris, Andrew
Andrew.Harris at jhuapl.edu
Thu Sep 4 20:27:24 UTC 2003
Hi -
How do I enable DEBUG flags when I compile a BSP? I want to enable
things like "SHOW_MORE_INIT_SETTINGS", "TEST_RAW_EXCEPTION_CODE", and
"DEBUG", etc.
But I can't figure out how to do this through configure. The
configure help says there are things like "CFLAGS_FOR_BUILD",
"CFLAGS_FOR_HOST", and "CFLAGS_FOR_TARGET", but if I want to build a BSP
(mvme2307), which of these should I use?
thanks,
-andrew
Andrew Harris andrew.harris at jhuapl.edu
JHU/APL (443) 778-3093
