Problem with gdb script
Brett Swimley brett.swimley at aedinc.net
Thu Sep 4 22:41:51 UTC 2003
I'll put together what I've got and send it out but it's really not any
more than what Joel had originally put together.  I do have a little
script function that sets up a pointer to the Task_Control structure
given the object_id.
Nothing too fancy yet, I'm afraid,  but feel free to use it !
Chris Johns wrote:
> Joel Sherrill wrote:
>> Could you email me what you are using and I will add it to CVS
>> and see if we can start trying to integrate it and improve it.
> Can I get a copy. I will update the scripts in CVS.
>> Chris Johns... didn't you know how to make them all of the form
>> "rtems subcommand" and add them to the documentation tree?
> I am not sure about command layering, but a simple 'rtems-*' would be
> a start, and yes documentation can be added to script commands.
>> I would really like to see more commands supported.  Next on my
>> list was a heap/executive workspace info command.
> Are you thinking of making calls from GDB to the certain code on the
> target ?
>> Eventually I would like to discuss add these to the gdb RPMs and include
>> them possibly include them automatically at startup.
> Good idea.
Brett Swimley
Advanced Electronic Designs
ph: 406-585-8892 fax: 406-585-8893
