sparc-rtems-size
Fri Sep 5 13:25:32 UTC 2003
Fabio Degiovanni - Eicas wrote:
> What are the exact meaning of the field "text" "data" and "bss" given by
> the sparc-rtems-size utility?
I was surprised that this wasn't in the binutils size man page. :(
.text is where the executable code goes.  Sometimes it may also
hold read only data.  .text should be able to be placed in ROM
or Flash.
.data is initialized global/static variables.
.bss is uninitialized global/static variables.
On top of that, you have dynamic heap and RTEMS work space usage
which cannot be determined by size.
> Thank you very much
> Fabio Degiovanni
