sparc-rtems-size
Tue Sep 9 13:24:27 UTC 2003
Fabio Degiovanni - Eicas wrote:
> Dear Joel Sherrill,
>                                using the tool sparc-rtems-nm --size-sort
> --extern-only I resolved my problem: I found out the name of one of my
> variable whose dimension where incorrect. I didn't know that tool, where
> can I find a manual o a list of these useful commands?
"ls /opt/rtems/bin" and then do man/info on each of the commands.
Seriously, there are a lot of commands and useful options.  I didn't
even know you could sort by size until I looked this one up this
morning. :)
I find the following useful to know when hunting an object sizing
issue.
   + size
   + nm -v (sort by address)
   + nm --sort-size
   + ld -Map (show why .o's are pulled in)
> I realised that calling sparc-rtems-size on an object file is not
> correct: it seems that the bss section is not computed correctly:
> I wrote this simple example:
> int a[1000000];
> int main(){
> return;
> I saw correctly 4Mb in the bss section calling sparc-rtems-size on the
> executable, but calling it on the object I saw 0 bytes in the bss section.
It is doing this natively on Linux so I don't know if this is a bug
or feature.
> Defining a as an initialised variable I saw 4Mb both calling
> sparc-rtems-size on the executable and calling it on the object in the
> data section.
Watchign size is important on embedded targets. :)
> Thank you very much
> Fabio Degiovanni
>>> Thank you very much for your help, I appreciated it very much.
>>> I need to solve compleatly the problem, so I have some more questions:
>>> -you told me that most likely the .bss section is not included in the
>>> output image. I presume that this happen always because the
>>> uninitialised data are created run-time. Am I right?
>> Since it is uninitialized variables, it is really just reserved space
>> in memory which is reserved in the linker script.
>> I have also seen linker scripts with minor errors which resulted in
>> extra large bss sizes being reported.  Is
>> your linker script in the primary tree or custom?
>>> -you told me that I must have some huge arrays declared in that code,
>>> but I presumed that my bss section would have been much smaller. I
>>> tried to do sparc-rtems-size to every object files and than I summed
>>> up and I found:
>>>  text    data     bss     dec     hex
>>> 117506  181240    4816  303562   4a1ca
>>> Is the difference between the object files size and executable file
>>> only due to the static linking of rtems libraries? In this case it
>>> seems that the umount of uninitilalised data is introduced by the
>>> rtems libraries. What's the difference between doing sparc-rtems-size
>>> on the executable and on the object files?
>> The libraries just like you think.  I don't think there is 9806288 -
>> 4816 in uninitialized data in
>> any of the libraries.  You are only pulling in about another 100K of
>> code but getting 9.4 MB
>> of data.
>> I think there might be a linker script file mistake in this case.
>> Which one are you using?
>> Also look at the symbol table sorted by size (sparc-rtems-nm
>> --size-sort --extern-only)
>> and see what's so big.
>> --joel
>>> Thank you very much
>>> Fabio Degiovanni
>>>> gregory.menke at gsfc.nasa.gov wrote:
>>>>> Fabio Degiovanni - Eicas writes:
>>>>>  > Dear Sirs,
>>>>>  >                 thank you very much for your answer, you have to
>>>>>  > apologize me, but I mistook the question. What happens to me is
>>>>> that the  > executable is smaller than what sparc-rtems-size returns.
>>>>>  > To explain better:
>>>>>  > -ls -l HISA returns 1869954
>>>>>  > -sparc-rtems-size HISA returns
>>>>>  >    text    data     bss     dec     hex filename
>>>>>  >  231488  183040 9806288 10220816         9bf510 HISA
>>>>>  >  > I understood well your explanation about the possibility that
>>>>> the output  > file is bigger than the sum of the .text, .data and
>>>>> .bss sections, but I  > cannot understand why  my output file is
>>>>> smaller than the sum of the  > ..text, .data and .bss sections.
>>>>> Most likely the .bss section is not included in the output image.
>>>> Correct.  And yikes!! You must have some huge arrays declared in
>>>> that code.
>>>>> Gregm
