GDB BDM on linux for a 68332
James Fitzsimons
jamesfit at paradise.net.nz
Wed Sep 10 05:50:56 UTC 2003
Hi all,
Sorry to post this slightly off topic post, but I figured someone on this
list can probably help me.
I am trying to setup debugging of my 68332 board with GDB and a BDM cable on
a linux host, but so far I can't get the test programs for the BDM driver to
complete successfully. When I run either the chk or cpu32-check programs (in
the test directory for the BDM driver) I get the following error:
[james at Mandrake test]$ ./cpu32-check /dev/bdmcpu320
BDM Driver Version : 2.a
Processor : CPU32
Interface : Eric's CPU32
Register test, 1 of 1 :
D00 : ........................................
D01 : ........................................
D02 : ........................................
D03 : ........................................
D04 : ........................................
D05 : ........................................
D06 : ........................................
D07 : ........................................
A08 : ........................................
A09 : ........................................
A10 : ........................................
A11 : ........................................
A12 : ........................................
A13 : ........................................
A14 : ........................................
A15 : ........................................
Initializing target
MBAR readback failed: No BDM error (yet!)
I tried ignoring this and running gdb anyway, but it complains about the
following command in my .gdbinit script:
set $sfc=5
I am guessing that these problems are related.
Can anyone provide me with some advice/suggestions on what the problem might
be?
Thanks very much,
James Fitzsimons
