mips: genmongoosev/start/start.S
Wed Sep 10 15:00:02 UTC 2003
Ralf Corsepius wrote:
> On Wed, 2003-09-10 at 15:28, Bill Gatliff wrote:
>>Ralf:
>>What do you see when you run objdump --disassemble on the
>>binutils-2.13.2.1-generated mipsbug.o?
> # cat mipsbug.s
>    sw  $8,0xfffe0130
> # mips-rtems4.6-as  -G0 -EB -mips1 -g0 -32 -v -o mipsbug.o mipsbug.s
> GNU assembler version 2.13.2.1 (mips-rtems4.6) using BFD version 2.13.2.1
> # mips-rtems4.6-objdump --disassemble mipsbug.o
> mipsbug.o:     file format elf32-bigmips
> Disassembly of section .text:
> 00000000 <.text>:
>    0:   3c01fffe        lui     at,0xfffe
>    4:   ac280130        sw      t0,304(at)
FWIW I get the same lw code output by gcc 3.2.3 and 3.3.1 for this
C function that is handwritten in start.S.
void f( int x)
   int *p = (int *)0xFFFe0130;
   *p = x;
It could be a bug in binutils 2.14.  Do you want to post it to
the binutils list and cc me?
> Ralf
