BSP for MIPS32 4KC
    Joel Sherrill
    joel.sherrill at OARcorp.com
    Wed Sep 10 18:47:12 UTC 2003
Feel free to file a PR on this and it will get fixed.
--joel
mikeci at acm.org wrote:
>>You sent this to me and not to the list.  Did you mean for it to
>>go to everyone?
>>>Hi!
>>>There is another thing here. Modules compiled with mips=3 and mips=1
>>>or mips=32 can't be linked together. This is main reason why I think
>>>we should stick with mips=32 instead of doing everything with mips=3.
>>>Does anyone have better solution?
>>And no.  The problem Ralf mentioned on the p4xx BSPs is exactly this
>>type of thing.  The RTEMS traditional solution is to have LOTS of
>>multilibs where needed and then depend on the linker to do the right
>>thing.
>>>Regards
>>>Ivica
> Hi!
> Yes, this was post for the list. Ok. I am satisfied with the BSP I
> currently have. There is still one more thing. I don't know if I should
> file this as a bug or not. This is the code defined in vectorisrs.c for
> r46xx or p4000:
> void mips_vector_isr_handlers( CPU_Interrupt_frame *frame )
>   unsigned int sr;
>   unsigned int cause;
>   unsigned int i;
>   unsigned int mask;
>   mips_get_sr( sr );
>   mips_get_cause( cause );
>   cause &= (sr & SR_IMASK);
>   cause >>= CAUSE_IPSHIFT;
>   /* XXX check this and think about it. */
>   for ( i=1, mask=0x80 ; i<=8 ; i++, mask >>= 1 ) {
>     if ( cause & mask )
>       CALL_ISR( MIPS_EXCEPTION_BASE + 8 - i, frame );
> The line      CALL_ISR( MIPS_EXCEPTION_BASE + 8 - i, frame );
> is in error. It should be:
>        CALL_ISR( MIPS_INTERRUPT_BASE + 8 - i, frame );
> Regards
> Ivica
