minimum heap size
Chris Johns cjohns at cybertec.com.au
Fri Sep 12 08:10:41 UTC 2003
Joel Sherrill wrote:
> It is where all malloc() requests come from so
> is strictly application dependent.
RTEMS (via newlib) does use the heap so this is not completely true.
If an application did not allocate any memory from the heap, I think you would still
need to provide a heap for libc plus other code to work. For example I think a printf
call results in an stdio buffer being allocated. I also know the DOSFS uses the heap.
I remember meantion of a heap size call so maybe a test of:
void Init ()
   print_heap_usage ();
would be worth a try.
  Chris Johns, cjohns at cybertec . com . au
