Newbie Solaris Question...
Christopher Plummer Christopher_Plummer at raytheon.com
Mon Sep 15 15:01:58 UTC 2003
Hey guys,
I am trying to get the RTEMS setup going on a Solaris box.  I want to get
the UNIX/emulator kernel running locally to do some preliminary testing,
but am having trouble getting GCC to compile.  Here's what I've done to
this point - I'm hoping someone can give the steps to get this thing
going...
Downloaded the sparc-rtems files for binutils, gcc, and c++ and unpacked
them.  I've exported the PATH to include the new opt/rtems directory.
Next, I created a build directory, cded into into and ran the configure
command for GCC - which goes good.  When I run gmake it errs during
compile with:
/home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
-B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
-B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/ -isystem
/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
-isystem /home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
-B/home/kplummer/opt/rtems/sparc-rtems/bin/
-B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
/home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x assembler
../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
xgcc: installation problem, cannot exec `as': No such file or directory
gmake[1]: *** [crti.o] Error 1
gmake[1]: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build/gcc'
gmake: *** [all-gcc] Error 2
gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
Any ideas?  Steps?
TIA,
Kit
Kit Plummer, Systems Engineer
Operations Research and System Performance Dept.
Raytheon Missile Systems
520-794-1552
520.794.0309 fax
christopher_plummer at raytheon.com
