Newbie Solaris Question...
gregory.menke at gsfc.nasa.gov gregory.menke at gsfc.nasa.gov
Mon Sep 15 16:56:19 UTC 2003
Christopher Plummer writes:
 > Yep, I've set the path as such.  Not sure what I did, but I am not getting
 > this error:
 > /home/kplummer/Files/SPARC_RTEMS/build/gcc/xgcc
 > -B/home/kplummer/Files/SPARC_RTEMS/build/gcc/ -nostdinc
 > -B/home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/ -isystem
 > /home/kplummer/Files/SPARC_RTEMS/build/sparc-rtems/newlib/targ-include
 > -isystem /home/kplummer/Files/SPARC_RTEMS/gcc-3.2.3/newlib/libc/include
 > -B/home/kplummer/opt/rtems/sparc-rtems/bin/
 > -B/home/kplummer/opt/rtems/sparc-rtems/lib/ -isystem
 > /home/kplummer/opt/rtems/sparc-rtems/include -c -o crti.o -x assembler
 > .../../gcc-3.2.3/gcc/config/sparc/sol2-ci.asm
 > xgcc: installation problem, cannot exec
 > `/home/kplummer/opt/rtems/sparc-rtems/bin/as': Exec format error
 > gmake[1]: *** [crti.o] Error 1
 > gmake[1]: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build/gcc'
 > gmake: *** [all-gcc] Error 2
 > gmake: Leaving directory `/home/kplummer/Files/SPARC_RTEMS/build'
 > The 'as' that it is trying to use is the one from the
 > sparc-rtems-binutils-2.13.2.1-2.t fi.
Can you invoke it by hand?  ie; as --help.  And do the rest of the
binutils work OK?
Gregm
